So guys I need some help, I've just put a series 1 rb25det from a running r33 into my s14 drift car. I've used the engine loom and dash loom (so I can use the cluster) sent power to the appropriate wires on the engine loom/ECU but I'm not getting any spark or ignition.
The car is bare bones and has ignition, fuel pumps and starter on a switch panel, does anyone have any info on how to get it up and running.
Cheers
Cheers robbo, just had a quick browse through it, hopefully there is something in it that will help. From what I can tell I've done pretty much what it says, only difference is that I'm not using any of the old 200sx looms.
It's basically a full track car so I just need the engine to run
Are you sure the ECU is powered up correctly? Can you attach a consult of some sort to the port to monitor?
ECU power needs the ECCS relay all hooked up correctly, that would be the place to start if the whole ECU is dead.
Isn't the fuel pump relay in the boot originally? Both my fuel pumps, starter and ignition switch are independently wired, basically ran switched 12v to the wires on that pinout that require 12v
Plugs have been pulled and checked for spark but I have nothing.
The second relay near the ecu isn't coming on, I'm sure one is eccs and the other ignition? I did find a pin on the white connector in the drivers footwell that powered up this relay but when checking for 12v output from it there was nothing.
Yeah there are variations in the looms from different years, but if you have 2 relays on is ECCS and the other ignition.
Per your diagram pin 16 should earth the ECCS relay when the ECU gets IGN on signal, so check out that part first.
I'm guessing the one that's clicking when ignition is switched is the eccs relay.
It seems the ignition relay is the one that isn't clicking which would explain the lack of spark. Even when I put power to the pin I mentioned on the I believe f3 plug in the drivers footwell there is no 12v out of the ignition relay
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
