Hi all,
This morning I took the car to my mechanic to have a new Nismo GT LSD (38420-RS015-BA) installed and he's just contacted me with some issues regarding bolt sizing and flange fitment.
So far he's told me that the bolts that came with the Diff assembly are too small, 12mm vs the 13mm in the car already. And also he cannot get the flanges to fit correctly.
I should mention that the car is a stock 1998 ER34 GTT, however it came as a factory auto and had been swapped to a (cursed) R32 transmission. I wouldn't have thought the diff has been changed but who knows.
As far as the gearing is concerned, I'm certain my ER34 has the AT ratio for final drive as the acceleration is noticeably quicker than another ER34 GTT I've driven.
My question is, do you have any idea what may be happening here? I would have thought there would be no issues installing the Nismo diffs.
There's also the issue that he doesn't speak much English, and I dont speak much Japanese, but he's a nice bloke and has been very helpful so far and dont good quality work on smaller jobs.
The rear ratio for AT is 4.08 vs 4.111 in Manual. This is utterly un-noticable. (about 1kmh per gear shorter/longer).
Do you really have a R34 GTT standard?
If any of the setup is to suit a N/A in the rear end, you'll have different axles to suit. If it isn't that - For some reason Nismo have two different part numbers for the R34, one for series 1 (98-2000) and one for series 2 (2000-2001)
The one you posted is series2. I am not sure what the differences actually are (or if it is even relevant.) But it is a different part number.
  • Like 1
Something doesn't add up here.
My car is factory 1999 GTT A/T and it had the 13mm bolts. It had an VLSD.
So this makes me think that if the Nismo P/N really matches and the unit was brand new unopened, that something went wrong somewhere down the line at Nismo (highly unlikely of course). I suppose it would make more sense the other way around: the car had 12mm bolts it and Nismo came with 13mm.
About the flanges: I believe all Nismo LSDs come with the drive shaft ends/stub axles/flanges so unless they don't match the driveshaft bolt pattern (in ER34 this should be 5 in a star shape), there shouldn't be any problems with them.
Note that you cannot use the original VLSD stubs with the Nismo, probably the splines don't match and one of them is too long anyway, so if your Nismo LSD didn't come with the stubs, then no wonder there's trouble.
  • Like 1
The acceleration sensation is subjective and if anything irrelevant anyway.
The part number is correct according to the Nismo catalogue, along with the chassis number and Nissan EPC.
I did get an update that he managed to fit the flanges and have since picked the car up. However, he did use the original 13mm bolts. Unfortunately he didn't get any pics of the work.
He made a comment about how disgusting the insides were and that he was unable to clean up all of the caked oil. The car has about 240k kms on it.
 1973578787_NissanEPC.thumb.JPG.e01cbbde2bcddcf60b83ac4259071e08.JPG887267623_NismoGTLSDPartNumbers.thumb.JPG.23cdedc92b93326eddb2ae6dcf08a30b.JPG
About the flanges: I believe all Nismo LSDs come with the driv e shaft ends/stub axles/flanges so unless they don't match the driveshaft bolt pattern (in ER34 this should be 5 in a star shape), there shouldn't be any problems with them.
I know right, luckily the mechanic was able to get the flanges in today - he told me it was super difficult - and I was able to pick the car up. However, he did not use the 12mm bolts that came with the diff.
It is odd, and even if Nismo were to have made a mistake - again, highly unlikely - you'd have thought it would have been corrected this far down the line. Where the mistake lies and what I am going to do with these additional bolts, I have no idea.
Well, glad you have your car back on the road again.
I installed an S13 Kaaz 2way on my ER34 and just drilled out the diff centre holes to accept the bigger bolts. I also transferred the ABS rings from the ER34 stubs to the S13 5-bolt stubs.
Going to go Nismo at some point so this was good information. Need to check things carefully.
Cheers.
  • Like 1
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
