I have a rattle noise that I'm 90% sure is coming from the gearbox. It sounds like an inconsistent rattle of something hitting the housing on the inside, it is not a steady tap. The car shifts fine, no grinds or anything but I don't aggressively drive or shift hard/fast since I've noticed the rattle either. So I ordered some shockproof lightweight to see if that would help and I drained it today, the plug is full of the expected shavings but nothing big, and the oil looked relatively clean while draining. I have a little wire feeler that I stuck up through the drain hole to feel around for any debris and found nothing...but about 6-10 cm behind the drain hole I found something loose that I can make move by pushing on it with the wire feeler and I think I can hear it tapping the housing if I push it back and forth. It is not completely free, it won't move around where I can pull it out or anything but it is loose enough to easily move up and down to tap the the gearbox housing by just pushing it lightly with a piece of wire. Anyone know what this is? I assume it shouldn't be loose like that but I don't understand why it hasn't caused any drivability issues.....time for a new tranny or rebuild?
Edited by damesta
With any luck that fragment will be magnetic. just use some short wire with a magnet on it to try and drag the part out....but bottom line is nothing should be loose in there so a teardown is in order.
  • Like 1
Thats what I figured, I have never opened one of these boxes up but I didn't think anything in there should be moving that easily. I was trying to explain as best I could but its not a loose fragment and is not freely bouncing around in there. It is still loosely attached to something (or possible sitting in an area tight enough to prevent it from moving anywhere), I can push on it with my wire lightly and move it up and down to make it do the taping noise, but I cannot freely move it around to where I can get it out.
I'm trying to think what could be reachable through the drain hole and nothing springs to mind.  Everything is pretty solid in there normally!  If it was a snapped off shift fork you would well and truly know about it!
Have you got a multi-plate clutch?  They're generally a pretty consistent rattle but if it's getting a bit old it could be sticking then releasing.
These are pics of my box in bits and there really doesn't look like there is anything that could be flapping around in there (to the right of the centre plate in the first pic and to the left of the plate in the second pic)-
20200218_215120.jpg.7a571af3d93338086230d64163393f95.jpg-
I don't see anything but not the best angles, the area I'm talking about is pretty much right where the bellhousing meets the center plate on the very bottom...its just out of reach for me to touch with my finger through the drain hole but it moves very easily pushing it with a wire. Even if something was supposed to be loose like that in there it shouldn't be loose enough to tap something else and make a noise. Its crazy to me that this tranny shifts normally like this and hasn't torn itself up yet.
my bet is it is something small and loose but hard to move because gearbox oil is very sticky....Lots of little pieces that could detatch and have the box still working OK like a synchro clip
Probably right....so here’s what I’m thinking. Since it shifts normally and I haven’t noticed any grinding or drivability issues maybe I can save this tranny. I think I’ll drop it out and pull the bell housing so hopefully I can get to the loose part and either remove it or fix it if it’s a clip or something. Then hopefully reassemble and reinstall.
7 hours ago, hardsteppa said:
Might be the drain flap at base of the centre plate. It moves, but shouldnt make any noise
Hmmm, does anyone have picture of this flap so I can visualize it? I searched but don't see a flap anywhere on any skyline center plate pictures I could find. But yes, that is exactly what it feels like, would be bottom center of the plate, feels like I am lightly opening and closing a hinged flap with the wire, the closing making the taping noise when it makes contact....could be that I can only hear it because it is closing faster/harder due to the transmission being empty right now.
Edit: Found a picture of an os giken gtr center plate with the flap intact, some of the other plate pictures I found of rb20/25 center don't have the flap intact but the hole for it looks lower and more centered than on the gtr box. I'm starting to think this is what I'm hitting, looks like it could move in and out a few mm and make a tap while there is no oil to cushion it.
Edited by damesta
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
