Hi,
Which gearbox oil would be recommended for me to use, Redline shockproof lightweight or heavyweight? It's for a R33 RB25DE that will be getting turbo conversion soon. Planning on using this gearbox, so want to make it last unless I can find a GTST one for a decent price. Doubt the oil has ever been changed lol.
I'm able to shift fine when changing gears slowly but if I change quickly, it'll usually crunches 1st to 2nd and 4th to 5th. Would this be classed as slightly bad or really really bad? It doesn't pop out of gears or anything as other posts and threads say.
Also I've noticed alot of these gearbox oil threads threads are a couple of years old now. Has anything changed since and is a better oil available or is Redline still the best to go for?
Thanks.
redline lightweight is good for improving shifting in boxes which crunch on fast(er) shifts due to worn synchros.
I would steer clear of it in new or rebuilt boxes with good synchros as it is not recommended for synchro boxes by the manufacturer
  • Like 1
Redline's light/heavy weight are "no turning back" options.  Once you start using either one it will begin to eat into the synchros.  Try their MTL first to see if if the crunch improves for you, if not go for the light/heavy weight.
  • Like 1
CORROSION PROTECTION The extreme pressure chemistry used in many gear oils can be corrosive to brass and bronze used in synchronizers and bushings. Most gear oils are corrosive at temperatures of 200°F. Red Line Gear Oils are non-corrosive up to 300°F and the MTL® in excess of 375°F. A corrosive gear oil can shorten synchronizer life by half and can also contribute to rust problems.
https://static.summitracing.com/global/images/instructions/red-synthetic gear oils.pdf
Also Redline only specifically say the Heavy Shockproof isn't recommended for most syncro boxes due to it being too slippery.
Go for the Lightweight, be sensible by not slapping gears and the gearbox will be fine. If you ever put a decent replacement in then go to a standard gear oil.
2 hours ago, GTSBoy said:
I have nearly 10 years of Redline lightweight in mine. It's fine - for a gearbox that wouldn't change gears at all with normal gear oil when we first installed it.
Redlines new poster boy, they should sponsor you.
Thanks guys, I'll give the lightweight ago. If I still have problems, then I may give the heavy one a try but will keep my eye out for a gtst box. It's not going to be trashed or anything so should last a while.
GTSBoy, you sold me on the lightweight with that lmao
A bit late for the party.
I got a RB25 box that had done some 160k KMs when I installed it. After the swap I decided to first go with some Castrol 75w-90/140 something-a-rather (recommended type anyway) and it was crunchy as hell. Synchros were definitely on the evening side.
So I put in the MT-90 Redline and while it still tends to give you a bit of a nudge when shifting, it works like a charm now for the most of the time and allows easy mid-powerslide shifts from 2->3.
There is talk of HW and LW fluids here, but are these two different from the MT-90 I'm using?
  • Like 1
    • Which model Maxima? This is good knowledge to have.
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
