Hey guys, so I'm starting to dig into my a/c problems on my r32 gts25. I am almost certain the system is empty and the compressor may or may not be good. I have ordered a new seal kit, fittings, expansion valve and drier to start converting it to r124a and fix whatever problems it has at the same time.
So first things first, someone did some slight wiring modifications at some point and added this relay to engage the clutch. I'm not sure if this is just replacing a factory relay with a generic one, of if they actually added this relay to the circuit. But this is very much not factory wiring. They have the 12v power coming straight from the battery with an inline fuse and the signal wire to close the circuit and send power to the clutch is coming from the loom (a small blue/red stripe wire). The clutch will not engage when the A/C is on right now and I get no voltage reading on the blue/red stripe wire, however, this may be because there is no pressure in the system and the pressure switch is not sending a signal to it...but if I put 12v to the signal post on the relay then I can manually get the clutch to engage.
So what should I do with this relay, completely remove it and return it to stock or use it as is? I know that the blue/red stripe wire originally went straight to the ac clutch single wire plug...so I’m not really sure what the point of installing this relay was to begin with. It does not allow the clutch to be manually engaged or anything like that, it still signals from the original wire and I cannot find any other modifications to the A/C wiring.
Edited by damesta
https://www.sau.com.au/forums/topic/482440-r32-rb25de-ac-help/
24 minutes ago, GTSBoy said:
Is it climate control? If so, did you realise that there is a full diagnostics suite available through the control panel? See the R32 GTR manual.
Yeah, I already ran through the diagnostics on the climate control, everything checks out ok, sensors and everything all work. But that diagnostic system doesn’t test the clutch, compressor or signal to it as far as I know. I’m really not trying to get it working right now, at this point I’m just trying to make sure it is wired correctly so I can start the r134 conversion.
6 hours ago, GTSBoy said:
Pressure switch is healthy, right?
As far as I know it is good, however, the new drier I will be installing comes with a new pressure switch so it will be replaced, that is the only pressure switch correct? Or are there 2 of them?
What I'm really trying to figure out right now is why this relay was wired into the A/C clutch circuit. Does anyone have the actual a/c wiring diagram for an r32? All I can find is the eccs diagram which shows basic routing but it does not show the full a/c wiring details on it.
Edited by damesta
Well, yeah. I was hoping that it would be telling you whether there was enough gas in it or not. Tried it with it plugged in and unplugged?
Yeah, thee R32 GTR manual has everything you need.
I haven't tried it unplugged, should the clutch engage if its unplugged?
And I completely missed that in the r32 gtr manual, I was thinking it was just the engine section until I looked again. Thanks
2 hours ago, GTSBoy said:
I don't think so. But discovering unexpected behaviours exhibited can be just as illuminating as when things do what you expect.
True, just checked, makes no difference when its unplugged. I guess just I need to do the conversion and charge the system, I'm going to go through all of the testing in the manual but I'm not sure if there is a way to directly test the clutch engagement signal unless the system is pressurized and the pressure switch is working...so kind of hard to determine what the point of that extra relay was.
Edited by damesta
More than likely something in the system stopped working and that was someone's hack workaround. Probably not a good sign.
I'm sure it was an attempt to work around the stock a/c relay but it makes no sense because it is triggered from a signal that is coming directly from that relay....so if the stock relay didn't work this one wouldn't either. But anyway....I pulled it out and have been through all of the testing of the circuit per the fsm and everything checks out fine, there is nothing wrong with the wiring/signals or any of the a/c electrical stuff. However, my assumption that the system was empty was correct, so I can't fully test it until the rest of my parts get here and the conversion/recharge is done. The only reason I can think of for someone to do this is if the clutch wouldn't engage because of low pressure and someone assumed the relay wasn't working and tried to add another one.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
