Hey guys, so I'm starting to dig into my a/c problems on my r32 gts25. I am almost certain the system is empty and the compressor may or may not be good. I have ordered a new seal kit, fittings, expansion valve and drier to start converting it to r124a and fix whatever problems it has at the same time.
So first things first, someone did some slight wiring modifications at some point and added this relay to engage the clutch. I'm not sure if this is just replacing a factory relay with a generic one, of if they actually added this relay to the circuit. But this is very much not factory wiring. They have the 12v power coming straight from the battery with an inline fuse and the signal wire to close the circuit and send power to the clutch is coming from the loom (a small blue/red stripe wire). The clutch will not engage when the A/C is on right now and I get no voltage reading on the blue/red stripe wire, however, this may be because there is no pressure in the system and the pressure switch is not sending a signal to it...but if I put 12v to the signal post on the relay then I can manually get the clutch to engage.
So what should I do with this relay, completely remove it and return it to stock or use it as is? I know that the blue/red stripe wire originally went straight to the ac clutch single wire plug...so I’m not really sure what the point of installing this relay was to begin with. It does not allow the clutch to be manually engaged or anything like that, it still signals from the original wire and I cannot find any other modifications to the A/C wiring.
Edited by damesta
https://www.sau.com.au/forums/topic/482440-r32-rb25de-ac-help/
24 minutes ago, GTSBoy said:
Is it climate control? If so, did you realise that there is a full diagnostics suite available through the control panel? See the R32 GTR manual.
Yeah, I already ran through the diagnostics on the climate control, everything checks out ok, sensors and everything all work. But that diagnostic system doesn’t test the clutch, compressor or signal to it as far as I know. I’m really not trying to get it working right now, at this point I’m just trying to make sure it is wired correctly so I can start the r134 conversion.
6 hours ago, GTSBoy said:
Pressure switch is healthy, right?
As far as I know it is good, however, the new drier I will be installing comes with a new pressure switch so it will be replaced, that is the only pressure switch correct? Or are there 2 of them?
What I'm really trying to figure out right now is why this relay was wired into the A/C clutch circuit. Does anyone have the actual a/c wiring diagram for an r32? All I can find is the eccs diagram which shows basic routing but it does not show the full a/c wiring details on it.
Edited by damesta
Well, yeah. I was hoping that it would be telling you whether there was enough gas in it or not. Tried it with it plugged in and unplugged?
Yeah, thee R32 GTR manual has everything you need.
I haven't tried it unplugged, should the clutch engage if its unplugged?
And I completely missed that in the r32 gtr manual, I was thinking it was just the engine section until I looked again. Thanks
2 hours ago, GTSBoy said:
I don't think so. But discovering unexpected behaviours exhibited can be just as illuminating as when things do what you expect.
True, just checked, makes no difference when its unplugged. I guess just I need to do the conversion and charge the system, I'm going to go through all of the testing in the manual but I'm not sure if there is a way to directly test the clutch engagement signal unless the system is pressurized and the pressure switch is working...so kind of hard to determine what the point of that extra relay was.
Edited by damesta
More than likely something in the system stopped working and that was someone's hack workaround. Probably not a good sign.
I'm sure it was an attempt to work around the stock a/c relay but it makes no sense because it is triggered from a signal that is coming directly from that relay....so if the stock relay didn't work this one wouldn't either. But anyway....I pulled it out and have been through all of the testing of the circuit per the fsm and everything checks out fine, there is nothing wrong with the wiring/signals or any of the a/c electrical stuff. However, my assumption that the system was empty was correct, so I can't fully test it until the rest of my parts get here and the conversion/recharge is done. The only reason I can think of for someone to do this is if the clutch wouldn't engage because of low pressure and someone assumed the relay wasn't working and tried to add another one.
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
