JC71 Posted May 25, 2021 Share Posted May 25, 2021 New ER34 skyline NEO GTT FS5R30A 5 speed transmission/gear box what oil should be used for initial fill?, and what oil after that? Link to comment https://www.sau.com.au/forums/topic/482444-er34-new-gearbox-what-oil-should-be-used/ Share on other sites More sharing options...
admS15 Posted May 25, 2021 Share Posted May 25, 2021 Brand new box is pre filled from factory with castrol vmx. Id run that for a thousand k's then drain and refill with a gl4 oil of your choice. Link to comment https://www.sau.com.au/forums/topic/482444-er34-new-gearbox-what-oil-should-be-used/#findComment-7952141 Share on other sites More sharing options...
JC71 Posted May 26, 2021 Author Share Posted May 26, 2021 much appreciated, cant find Castrol vmx here in the states, so i will go with Redline MT-90 GL-4 Transmission Gear Oil . thanks Link to comment https://www.sau.com.au/forums/topic/482444-er34-new-gearbox-what-oil-should-be-used/#findComment-7952165 Share on other sites More sharing options...
admS15 Posted May 26, 2021 Share Posted May 26, 2021 That will work fine and is what i also am using. Link to comment https://www.sau.com.au/forums/topic/482444-er34-new-gearbox-what-oil-should-be-used/#findComment-7952166 Share on other sites More sharing options...
