Hi all,
Here is my little drift pig, needs some work.
This forum seems like a ghost town, the posts are few and far between.  Is everyone posting on FB these days, or is there another forum I'm not aware of?
Cheers,
T.
Edited by V8 GTST R32
  • Like 5
There is nothing new under the sun.
Build threads have a fair bit of activity for general "This is my plan/this is what I am doing" sort of things.
Gonna have to ask you - Is that the CAPA charger kit? Asking for a friend.
A friend is me, who has a LS in a R34 and figured it 'should' fit. Clearly does.
Hi there,
Yes, it’s a CAPA. Fits nicely. This one is rated up to 775hp. Should be enough. I like the instant torque
Cheers,
Any idea which one you ended up going with? I've had that page open for several years, figured there would be some compromise (I need AC, psteer, street legality lol)
I'm making the assumption you've got enough skills to put a LS in, adapting an intercooler kit to fit it would be no worries (at that point)
Oh well, enjoy the road less travelled (relative to me!)
V3-SI
it has PS, no Aircond  not Street legal lol
  • Like 1
1 minute ago, V8 GTST R32 said:
V3-SI
Is the no aircon dependent on the pulley for the charger? Or just because its a pain in the ass and not required. From what I read about the Capa kits they dont mention losing aircon for the commodores, so I assume their solution continues keeping stock AC...
One of the things I got heavily recommended was the Crow solid tensioner kit, to avoid throwing belts when you back off throttle at high RPM, instead of the spring loaded one. Something to look into before it becomes a problem for dorifto!
Fitting the Aircond is on the to do list, maybe, no great hurry. Do you have a link to the crow kits? Can’t seem to find anything with the Google. Wouldn’t want the pig to throw a belt.
I'm thinking that the future of crowded conversions is to use EWP and EPS pump and free some space next to the supercharger/alternator for the air-con compressor.
But then....now that we're in the era of stop-starts, hybrids and electric cars - air-con compressors with electric motors are going to have to be worth a look at also.
Sorry I had to re-google. Comp cams make one, not Crow, I knew it was some cam company..
There's also various copies out there, or other versions
Billet Belt Tensioner for GM LS1, LS2, LS3, LS6 and LS7 (compcams.com)
I bought this one on the advice of the VASS engineer who suggested I should get one, can confirm it installs easy, works perfect, seems good etc etc.
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
