R33 gtst and have done the CD00A swap. Ratios not great with 4.11 so bought a manual 350Z R200 diff with 3.5 ratio thinking I can swap the crown and pinion over into my gtst housing (with s15 Torsen/helical gut). All going well and proper (after ‘years’ of research), the internals are not the same - mostly the pinion dimensions.
This post is to spread awareness.. Also looking for pointers if any..
From the outside dimensions of the 350Z housing, the front mounts are pretty far off so no idea how that would even bolt into the R33 subframe, even with GKTech off centre solid mounts.
Z33 on left, R33 gtst on right. Notice massive difference in front housing mounts (height) and pinion thickness (far off). Definitely not compatible.... crown fits but obv pointless. Happy customer.
  • Like 2
https://www.sau.com.au/forums/topic/482452-350zz33-diff-ratio-into-r33-r200/
Neat gearbox's make ratios.
I have a 350z diff in an r33 frame in an s13 .... haha
The offset front bushes worked a treat. The rear housing ones not so much.
I think a custom rear cover with two bolts would be the best way, with correct alignment for the r33 style holes.
Oh and for awareness also, I learned there are at LEAST 2 types of 350z diff housings, given the wide spread of ratio's the offset is different in the front to accomodate different sized pinions.
Edited by Butters
I have also put a 350 3.5 diff in my 32, with 34 subframe and GKTech offset bushes. I have also found a 2 bolt cover from the states i am waiting to arrive to see if i can use it
  • Like 1
Please check my pics of the two diff housing next to each other. Is your 350z diff the same height on the front two mounts? It seems way out and.. I’ll have a test fit later in the subframe and put some more pics up but from the eyecrometer, looks heaps out
Yes it sits different and adjusts the pinion angle as a result.  Angle still measured up fine though on mine.
This is not a like for like swap, it is a cheap gktech kit :)
(Oh and noting the GKTECH r33 subframe into s13 kit actually tells you to bash your chassis with a hammer for clearance ..... WTF !!   We notched the subframe instead. )
I was not happy with axle height drop that was a result of the rear bolt position and yes likely the front also.
It is all working well though thus far but only limited use.
Edited by Butters
  • Like 1
  • 3 weeks later...
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
