Why? And what sort of GTR does that? R32? No. R33? No. R34? No. All have dedicated amber indicators.
Besides, in a car as modern as a G37, the indicators and brakes lights and so on are all driven by the BCM. You can reprogram the BCM to flash whatever lights you want, without buying some tacky clear plastic lens Altezza uleh lights.
https://www.sau.com.au/forums/topic/482455-gtr-tail-lights/#findComment-7952285
13 minutes ago, Robzilla32 said:
Doesn't the ADM R32 GT-R have this config?
No. ADM R32s had a different setup with the outer of the outer as brake only, with amber indicator in the centre of the outer (instead of it just being a reflector). This because ADRs require that no permanently lit rear light may reside outboard of the rear indicator (which is what the JDM tailights have).
All imported R32s are supposed to have the wire linking the tail light input to the outermost light cut, to approximate the ADM config and comply with ADRs.
https://www.sau.com.au/forums/topic/482455-gtr-tail-lights/#findComment-7952295
Ah, OK thanks. I stand corrected.
On your 2nd point, I imagine this isn't performed consistently or "cut" may be translated to "disconnected."
I don't think I have noticed on R32s this but probably not looking either and would have assumed the light was out. The wiring on mine is intact and looks original.
https://www.sau.com.au/forums/topic/482455-gtr-tail-lights/#findComment-7952296
8 hours ago, Oxide_g37s said:
Hahah yea the guy I brought it off imported it lol but still parts are not easy to find for the car trying to find tail lights that turn your led lights that also function as your turn signal
I have the g37 tail as turn plug and play for sale If youre really that interested.
Took it off My v36 prior to sale.
Just makes the entire light flash as an indicator. I did like it, each to their own.
  • Thanks 1
https://www.sau.com.au/forums/topic/482455-gtr-tail-lights/#findComment-7952298
Mine was cut. Needed a patch splice soldered in to put it back the way it should be. It was supposed to be done in the compliance workshop and inspected by the rego people. I suspect that SA/Regency were more thorough about such things. Funnily enough, my car has been back through Regency since and they didn't even blink. I think they cared at compliance time because it was written down as a thing they had to check. But they probably actually only cared from a paperwork/auditability point of view and not from a technical perspective, because it's a pretty silly rule.
https://www.sau.com.au/forums/topic/482455-gtr-tail-lights/#findComment-7952299
