Hey guys, quick question regarding coilpacks
Stag is loooong overdue for a service (still haven't fitted the coolant bypass mod purchased from Scotty nearly 3 years ago!)
Wondering whether it's worth spending the extra $$$ for Splitfire coilpacks or just sticking with stock
My Stag hasn't been heavily modified and likely won't be so imagine stock will be more than up to the task?
It's a VQ25DET with turbo-back exhaust, may do a front mount later down the track but that's it
https://www.sau.com.au/forums/topic/482463-splitfire-vs-stock-coilpacks/
https://youtu.be/4d3nrBZjYKA?t=478
Splitfires were tested and seem to be all over the map there, but it's hard to say if the reason why the used RB25 coil was so bad was because it was old or not. Personally I've always been skeptical of going aftermarket for these kinds of parts, I bet the OEM coilpacks will end up comparable to a Splitfire in VQ applications.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
