Do you have the wrong style of bellhousing (ie push instead of pull) or none at all? Whether push or pull the bellhousing should have the slave cylinder mounts cast into it(you may need to drill and tap them), and everything else in the bellhousing is the same.
However, the front plate for the gearbox is different between push and pull due to the different thrust bearing mountings
