After years of delays hold ups, lack of motivation... I Got the Engine done and took the old girl where she belongs, back to the track. 95% off all my research was on here trawling the forums for engine build info. Ive got vids on all the rebuild including every failure along the way but it was all worth it because.... well look below i's awesome 380RWHP on 14psi running her in, can't wait to turn her up.
Edited by Tangles01
  • Like 5
https://www.sau.com.au/forums/topic/482471-r32-gtst-time-attackhill-climb-car/
Hey mate, great vid. How do you get 380 RWHP on 14 psi? I am running an RB256DET with same RWHP but at 20 psi.
Can you tell me what you have done to the engine as mine is pretty standard apart from forged internals, balance and bigger injectors with a Nistune board and LM TD06/25G turbo on a standard manifold.
Thanks.
GTX-3076
10.5:1 compression
E85
262 tomie cams
Hand ported head
VCT
Custom 6boost style mani
3.5 inch zauzt
690nm peak torque
And it's fresh obviously. I need to do a comp test now it's run it.
More supporting stuff but those are the power makers.
All the build detail is on the channel
Edited by Tangles01
15 hours ago, Tangles01 said:
GTX-3076
10.5:1 compression
E85
262 tomie cams
Hand ported head
VCT
3.5 inch zauzt
690nm peak torque
OK now I see why thanks. Yes, should be a bullet once 20 psi dialled in.
I'll have to be honest, I winged it on that lol. But head and block were virgin just got a skim for the MLS gasket and sent it. I did hand rotate her, clear is clear.
Edited by Tangles01
  • Haha 3
6 minutes ago, Tangles01 said:
I'll have to be honest, I winged it on that lol. Bit head and block were virgin just got a skim for the MLS gasket and sent it. I did hand rotate her, clear is clear.
That's not true mate, clear by hand vs at 7000rpm are 2 wildly different things!
Yes that's true mate. but still it works. And there was a silly timing issue where if it were close it would have kissed the valves, so I'm pretty confident it's okay. I might have gotten lucky, I might have measured the piston height. It was that long ago when I did it I can't honestly recll, but I remember not doing much about it, and not doing it right if I did anything.
  • Like 1
  • 4 weeks later...
On 13/07/2021 at 1:57 PM, Tangles01 said:
1.53.001
1.53.001
Hillclimb looks great. Much better than what we have here in NSW. Where is it located?
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
