8 minutes ago, Duncan said:
They are syncroniser clips, and would more commonly be found holding your syncro hubs together.
Did you change your oil for a reason?
Thanks duncan, Is it common for these syncroniser clips to fall out? How long do gearbox's last with them missing?
I had the gearbox rebuilt 2-3 yrs ago but it always felt a little sloppy, still works fine just a little notchy. Thought I'd change the oil...
yeah sorry I'm no gearbox expert. I guess it needs to come apart and may as well be checked/rebuilt while out.  The clips/keys hold the synchro hub assembly together and I think there are 3 per hub so perhaps the other one is holding in there for now, I was wondering if it was crunch shifting between a particular pair of gears.
  • Like 1
Those particular shifting inserts are from the 1st / 2nd gear selector coupling from your main shaft assembly, and as Duncan mentioned there is 3 if them.
Only a matter of time before your box will not select 1st or 2nd properly and is totally possible to lock the selector up completely.
Pull box and get it fixed, or you'll definitely do more serious damage to main shaft gears, synchros or coupling components.
This is absolutely not a "see how it goes" problem - you will kill your box if you don't address this now.
  • Like 4
Thanks BK, I'll get some quotes for a rebuild vs. a new box.
well, your profile nor post says which car / box, but potentially much cheaper to pull and rebuild. some of the Rb boxes are getting very expensive these days.
Few hours labour for box in and out if you can't do it.
depending on whether the bearings and synchros are still good to reuse it may just be a few hours to refit the keys.
  • Like 1
On 07/06/2021 at 9:56 AM, dyl33 said:
Yeah I'm a little annoyed, I knew somthing wasn't 100% right when i picked it up.
It was rebuilt by Gavin Wood Autotech on the Gold Coast, but he has since gone out of business.
Those solid inserts hold the 2 large circular springs on either side of the 1st / 2nd selector hub for the synchro baulk ring and is the same across all RB 5 speeds.
The 3rd / 4th inserts are a spring type clip and look like this when broken:
Should look like this:
Its way more common to pop the 3rd / 4th clips. The 3 ways these inserts come out on all gears is from:
1. Incorrect installation as they are pretty fragile.
2. Shifting like a Muppet, banging the gears through and forcing the shift.
3. Using a gearbox oil that is way too thick for the synchro to operate correctly like a diff oil or Shockproof. The thick viscosity actually will have a negative effect on the synchros to do their job and unnaturally load other components like shifting inserts, springs and sliding hubs.
  • Like 1
On 07/06/2021 at 11:53 AM, Duncan said:
A little off track, but I understand those clips you've shown are series1-2 R33. Apparently s3 R33 had a better designed clip installed and retrofit is possible.
Yes correct, that 3rd / 4th insert is a pre 97 clip. The solid insert on 1st / 2nd never changed but your correct, the 3rd / 4th spring type insert changed on the post 97 boxes to a solid two spring type design.
To retrofit to the later clip on 3rd and 4th requires everything to do with the main shaft 3rd and 4th to be changed including main shaft 3rd / 4th gear, synchro baulk rings, sliding selector collar - everything. Even the 3rd / 4th selector fork needs to be changed as it won't locate into the old selector collar. Its about $800 - $1000 worth of just parts to convert.
All of these parts required for the conversion is also what you need to do to go to a ungraded synchro gearset like a PPG, PAR or OS giken on an old box as they are all designed around the post 97 synchro update on 3rd / 4th - a cost not usually factored in when upgrading a synchro gearset.
  • Like 2
On 20/06/2021 at 10:28 PM, AleksandarR33 said:
They are shift inserts for 3rd & 4th gear, from month/year 06/97 onwards.
No, as mentioned in the original picture they are the 1st / 2nd gear ones.
Why do people with no idea what the hell they're talking about try and chime in on something as fact ?
It is the 1st / 2nd solid insert from the pics.
You have never built a box then have you.
I have - lots.
The solid ones are for 1st / 2nd, as they have a circular spring either side of them to provide the spring tension. The spring type looking ones are for 3rd / 4th as they are the spring.
Posts like this really shit me as it just contributes to misinformation from internet mechanics. If you don't know what you're on about - don't comment.
See below, same part for multiple Nissan boxes:
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
