Hey guys, so I recently purchased a 1993 R33 Skyline GTS series 2, they are n/a and I’m having lots of trouble finding threads and stuff on just information for them.
I’m currently working on getting it roadworthy and don’t have much to go, I plan on making it my daily but I also want to do some cool things to it but I know close to nothing about cars. In the future I hope to do a manual and turbo conversion but that won’t be for a few years and by then I could possibly just buy a gtst haha.
But any information or help you guys could give would be awesome, I don’t even know exactly what model it is because there is so many from what I can tell on the Internet but as far as I can tell it is an ER33 series 2 gts n/a
again thanks for any replies <3
Welcome to the forums! It will help if you add location to your profile as different parts/specialists are available in different places.
If you want to know more about the factory spec of your car, Nissan's parts software FAST has the original details of how it left the factory but we will need the japaneses VIN from the firewall, it will be something like ER33-xxxxxx.
You said you need to get the car roadwrothy, what is wrong that needs to be addressed?
And, in most cases turbo and manual conversions don't make financial sense, although that could be changing as the price of many of these cars are going up, not down, these days....
Just as a FYI, Series 2 came out 1996 onwards. 1995 had a kind of parts bin approach which everyone called Series 1.5.
The front headlights on your car are Series 1, being a 1993 I would safely say it's a Series 1 :)
Don't bother doing a turbo conversion, just do an engine swap with something more fun when the time comes.
Thanks man! Okay no worries I’ll add that into my profile but yeah I’m located in Victoria near Melbourne.
Is FAST like some sort of website that they have or something? I’ll have to sus that out but the VIN thingy you asked for is ER33-005985.
So with the roadworthy, I’ve got to pull the fuel tank out and clean it out because it apparently has fuel that has been sitting there for a while and turned into some sort of slime or something stuck to the bottom of it. I’ve gotta chuck a RHF park light in, either replace or fix a puncture on my RHR wheel. Need to replace front caster bar bushes. And another thing that I have no idea how to fix is the gearshift indicator is sticking, it shows up fine on the dash but next to the shifter if I move it down it stays on the one above (Say if I had it in reverse and pulled it down without pushing the button in, it will go into neutral but not show that it’s in neutral. And if I push down the button on the shifter it will go into reverse but show that it’s in neutral.) the glue is torn in the boot seal, and I need to fix a rust hole in the boot floor.
I recently had it in the auto elec too and found that the alternator was stuffed, so I’ve had a brand new one put in and now the battery side of things is all good.
And yeah that’s what I’ve been thinking, currently it’s definitely not worth it but things could change in a few years time and I definitely don’t plan on doing it any time soon hahaha.
Ahh okay, it’s been really hard for me to find out for sure what the exact model is but you’ve cleared that up for me now, cheers a bunch man!
And yeah actually that sounds like a much better idea, will definitely keep that in mind going into the future!
  • Like 1
But the simple way is just go to the R33 GTS page at GTRRegistry and all the details same as FAST are there.
Edited by Rusty Nuts
additional information
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
