Hello all! Hope you are well. I just have a quick question. I have a few small chips in my paint and I'm looking to get a touch up bottle of paint for this. I have a 1991 R32 GTR painted in KH2. When looking for KH2 I find allot of Charcoal Pearl Metallic KH2 and obviously that's a different name from Gun Metallic Grey KH2. The code of KH2 is obviously the same but names are different. Did Nissan just change the name at some point but they are the same paint or if I buy the Charcoal Pearl Metallic KH2 it will be different from my current paint on the car. Thanks for the help in advance. Have a wonderful night/day and I look forward to hearing from some of you!
https://www.sau.com.au/forums/topic/482511-paint-touch-up-on-r32-gtr-kh2/
21 hours ago, GTSBoy said:
Metallic touch up paints bought at a distance are a waste of time.
Take it to a trusted crash repairer and get them to match and mix you up a small amount for brush touching.
Thank you! Yea ive thought about this im just not sure how much thats gonna run me. I will look into it thought so thanks for the advice.
29 minutes ago, GTSBoy said:
Does it really matter?
No it doesn't matter I'm just asking for hell of it... It matters in the sense that its easier to find a charcoal grey metallic KH2 touch up can over a Gun grey metallic KH2 can. Also cheaper.
I think my point is more..... what does it matter if you go to a shop and get a matching mix for, say, $100, vs. spending $30 on a touch up pen that doesn't match. You're not blowing your money. You are spending your money correctly (when you spend more to get proper stuff).
  • Like 1
They are likely going to be different colours. Best way to know for sure is still going to be to go to a paint supply shop and just ask them to compare the Hex code for the two colours.
And then while you're there, get them to mix you up a can for cheaper than you would pay to get off-the-shelf non-matching junk.
  • Like 1
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
