2014 Forester XT suspension
Hey there rob, just looking at the car. I’m quite interested in buying if your still selling
He's already pulled the motor, and I believe sent it to the builder. TurboTaipan has a cool build thread in the projects area you can follow on for more updates too
Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point. Cheers
It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
