Hi,
The engine bay of my 32 GTR always had this dull and dirt-like colour to it since I bought it. I shrugged it off but its been a while so I figured its time to fix it.
The car is in its factory colour (KL0 - Spark Silver Metallic) but the engine bay looks "dirty" and I have seen on other 32's which are this colour which have a sort of whitish-grey engine  bay. I'm pretty sure the car hasn't been resprayed and the VIN matches that of a KL0 car so I think it just needs a clean.
If this is the case, how should I best go about it because I don't want to damage the original paint underneath and just clean away the top layer given that's what needs to be done.
Any help appreciated.
Thanks
https://www.sau.com.au/forums/topic/482530-engine-bay-respray/
All i know is I cleaned my R32 Gtr engine bay last weekend, probably had 30years of grease built up, as I was scrubbing off the grease the original paint was stripping off, never had this issue before cleaning an engine bay. Im planning on respraying anyway but yeah, I would avoid any harsh cleaners and use a car soap before touching the harsher stuff.
Goodluck
  • 2 years later...
On 6/19/2021 at 3:24 AM, Old man 32 GTR said:
Do this, then paint bay, any painter can paint back to factory spec if that’s what you’re after.
How many hours of work did it take you to get to that point? And how do you get the car to the paint shop like this?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
