Hi all,
I've been recently getting back on track in the 34 and figured it was time to take the plunge and upgrade the gearbox.
I bought the car late last year, it was originally an auto, though the previous owner (or one of) swapped the gearbox with the less-than-adequate RB20det box. This month I have been accumulating parts to convert it to the 30A transmission; bought the 34 tailshaft from the UK for pretty cheap as they're going for 100,000JPY ($900-ish) here (Japan) and this week placed an order for a new 30A from Nissan.
The good news is, a lot of the harder to source parts I already have from the previous swap. However, I'm not 100% clear on what I can keep and what needs replacing.
I know there's some funny business involved with getting the 32 mechanical speedo to work with the 34 one, but am not clear on what modifications would have been made and how to reverse them if necessary. From what I've read, the modifications take place on the sensor side. Although, I have come across information regarding calibration of the tachometer.
Will the master cylinder / lines be reusable for the new transmission?
I've put together the following list, and it would be great if someone could point out anything I'm missing.
Component Part Name / Number Unit Price Shipping Total
Transmission FS5R30A 32010-AA520 ¥214,000 ¥15,000 ¥229,000
Propeller Shaft Nissan 37000AA500 ¥39,313 ¥30,000 ¥69,313
Clutch EXEDY ER34 Clutch 3-piece set 30210-AA001 30100-AA068 ¥42,350 ¥880 ¥43,230
Flywheel NA     ¥0
Spigot Bush NA     ¥0
Shifter Nissan 32839AA501/32839AB000 ¥5,387   ¥5,387
Clutch Master Cylinder ?     ¥0
Clutch Slave Cylinder Nissan 3062012U20 ¥10,753   ¥10,753
Clutch Master - Slave Lines ?     ¥0
Pedal Assembly NA     ¥0
Transmission Oil       ¥0
Clutch Fluid       ¥0
Labour   ¥100,000   ¥100,000
Resale (old parts)       ¥0
Total   ¥411,803 ¥45,880 ¥457,683
Edited by GoHashiriya
Spelling
You'll likely need a throwout bearing for the clutch, if it doesn't come with the clutch.
You'll likely need the correct transmission crossmember. The one that's under the RB20 box is probably the wrong one. They are stamped A, B and C. You can usually grab one of each from a wrecker/workshop and work out which one is needed then take the others back.
The clutch MC should work. It would be hard to believe that they put an R32 MC in there when the right thing to do in the first place would have been to put in a 34 one. Not that it should make much difference in how it works anyway.
Just get a new braided clutch line to replace the hardlines anyway. Easier and better than keeping and worrying about the old one.
The speedo is possibly a no brainer. The RB20 box has a mechanical drive via cable to a mechanical speedo head. If you have an electronic speedo head in the R34, then there's no mechanical drive. So it would be more likely that someone found an electronic sender to fit the 20 box. That's not a common thing to do, because no-one really does the conversion that you have. All the knowledge is around making a hybrid drive from a Navara to suit the big box in an R32 to drive the mech speedo. You need to work out what you have in the way of a speedo drive and head to work out what you need. If you have an electronic setup now, then all you're going to need is the appropriate speedo drive for the box. Of course, the calibration might not suit the speedo head, seeing as it originally used to work with whatever automatic speed sensor used be in there. The tacho has NOTHING to do with any of this.
You should do some searching on here for the thousands of words I have written on speedo setups for these cars.
  • Like 1
Appreciate this alot!
From what I can see the R34 AT/MT crossmember is the same - going by part numbers. I did find some information amidst the leagues of info on this site that said the RB20 box will fit the AT R34 crossmember (potentially was an R33) but you would only be able to utilise two bolts to mount it. I'll double check this. Thanks for advising on the crossmember identifiers.
I'll expect to do some dismantling of the speedo sensor and a bit more digging when we do the swap.
  • 2 months later...
Hi all, the box is going in on Monday,
Can anyone confirm whether Nissan fill the gearboxes with oil when ordered from the factory?
I've ordered some 75W90 castrol for the after break-in change but potentially will need to use it before the transmission goes in.
Which Castrol exactly ? The Synthetic Syntrax 75w90 I presume ?
If so, from my experience I would not be using it as it's doesn't seem to play nicely with the synchros at high rpm. I mean you could use it as a break in / flush oil, but as a GL-5 diff oil it just doesn't shift properly at high rpm, which seems to be a common theme with GL-5 only oils.
In synchro GTR transmissions I myself have generally used Castrol, and found the most suitable to be the 75w-85 GL-4 oils as per original Nissan specification.
Castrol VMX-M 75w-85 or VMX 80w for a mineral or Castrol Syntrans 75w-85 for a synthetic is recommended, both are GL-4 spec.
  • Like 1
Actually it was a little difficult being in Japan as the products aren’t identical. I ended up with Castrol syntrans 75w90, whilst I was looking for syntrax. The description (translated) reads as this:
“Castrol SYNTRANS Transaxle 75W-90 API GL-4 + Thin Trans Gear Oil Mission Oil All Synthetic Oil FF Car Transaxle Combined”
On the can it says transaxle, manual transmission and FF.
Cheers for your input - being unable to shift properly at high RPM would be pretty inconvenient, so If it is incorrect, I’ll just use it as break-in oil.
Aha ! Yes this is not sold in Australia anymore but used to be under the old grey bottles as TAF-X, as noted on the top of your bottle. Haven't seen this in over 10 years here, it's a good oil.
Should be no worries as its basically a 75w-90 GL-4+, which is the closest equivalent to our 75w-85 Syntrans GL-4.
It will be absolutely fine 👍
I usually break in / flush with the VMX-M and then switch to syntrans.
I guess Castrol Australia saw no point importing a synthetic GL-4 in 75w-85 and 75w-90 weights as the difference will be negligible.
Here's the spec sheet on your oil:
BPXE-9ZWGML.pdf
  • Like 1
I appreciate this a lot. Thanks for confirming!
I’d been using the U.K. castrol site (as I’m a U.K. citizen) for comparison but couldn’t  match anything up.
I’m unable to find the VMX on a quick search but will check if there is a comparable over here for run in. At $100 (US) for the TAF-X it seems a bit wasteful to bin it after 1,000km. Ah well, we’ll see.
Yeah I know -the Castrol vmx-m 75w-85 mineral is about $50au for 4 litres vs the $40 - $50au a litre for Syntrans.
Just look in Castrol where you are for a GL-4 mineral around 80w for a suitable first run oil, as I'm sure there will be something equivalent.
  • Like 1
Thanks again. As per the Castrol  JP site we have:
TRANSMAX MANUAL 80W-90 ($9 US p/l)
  • API GL-4, GL-5
  • SAE 80W-90
  • Partially synthetic oil
- TRANSMAX MANUAL 75W-90 ($15 US p/l)
  • API GL-3, GL-4
  • SAE 75W-90 *
The first one seems applicable to the run-in case and at less than half the price seems more suitable, financially.
Just to clarify for anyone searching: the new transmisssion came part-filled with oil from Nissan. We added about a litre of Castrol TAF-X before it started leaking from the fill hole. Shifting is fine - a tad notchy to begin with as expected but I've been shifting slow during break-in anyhow. I will be changing the oil in arround another 500kms, likely this month.
As GTSBoy mentioned, crossmember was different - it was the B-type under the RB20 box. Luckily was able to order another from Nissan quickly.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
