Hi guys, is the top layer of the front headlight a replaceable part or do I need to order the entire headlight? Mine's starting to show its age (turning yellow, scratches etc.) so was hoping to replace just that part or get something that blends in with the car a bit better. If possible, what's the part number that I need to order / from where?
Thanks
https://www.sau.com.au/forums/topic/482537-v36-front-headlight-oem-parts/
Very common
Get a professional headlight lense restoration (one who takes the headlight apart and does the lenses on both sides, I've had this done. Was $180) if you're In Brisbane QLD "dans custom car lights" done mine.
  • Like 2
Unfortunately the lenses can’t be replaced. You need the whole headlight assembly. Morimoto have made replacement lenses for the 370z & could make the same for the V36 but there is no guarantee.
The yellowing can be cleaned up but mine has like spiderweb cracking in the lense which cannot be fixed, only replaced 😔
That's pretty easy to clear up. As said already, get a headlight restoration kit or get a pro to do it for you (pretty easy to find on Facebook).
I found the Philips kit pretty good. You'll also notice improved headlight output as your lenses are clear/transparent.
  • 1 year later...
You'll find lots from the the US on ebay but they are for left hand drive cars and the headlights will blind on coming cars. So avoid them.
Check some of the wreckers in your area
