Hi guys
The dash and some interior trim pieces is starting to give away in our V36 2008 370GT coupe. Is it still possible to order spare parts specially for the dash? If so, what's the best way to order the OEM parts in?
Otherwise I was thinking of getting a dash mat or custom ordering one: https://www.fitmycar.com/au/nissan-skyline-sedan-v36-2006-2014-dash-mat-shevron/5041
Cheers
yes, that would be the correct part, but you would be looking at A$1k plus freight for one.
I had the same thing happen on my 05 V35 sedan a few years back.  I ended up finding one at a wrecker at the other end of the state and ordered it after they said it was in 'excellent condition'... It turned up with more cracks than mine had, so I had it re-covered by an auto upholster who really did a sub-par job, but at least it isn't cracked now..
Hi there
About 2 years ago I was searching for a new dash pad for my 2008 370GT ( old dash was sticky and falling apart) In Australia and Japan, either not available or over $2000 from Japan.
I did find that a new part number had been listed.
I gave the new part number to my local Nissan dealer, at South Tweed NSW.
BINGO !  5 genuine Nissan dash pads held at Nissan Vic.
One week later I picked  up the new dash from my local Nissan dealer. $1280 including freight.
I think the new part number was the same as the previous one, but finished with C
I hope this helps.
@gillies2001 Is your vehicle the base model (non S/P variants)? Same as mine in that case. Would it be possible to share / PM the part number you had ordered and invoice (if still accessible)? I will then take that info to my local Nissan dealer to see if the same OEM dash pad can still be sourced locally.
Was it much hassle / costly to get it fitted?
Cheers
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
