I've been looking into building an RB25 on the side for awhile and finally came across a well priced one. I have a few quick questions before I move forward as I know nothing about the neo engines.
1. What exactly is different between an S2 RB25DET and an RB25DET NEO? From what I have read, it seems superior in everyway.
2. Anything weird I should know about putting these in an R32? Is there anything vastly different between an S1/S2 RB25DET swap besides ecu/wiring?
3. This is an auto RB25DET NEO. Besides the tranny and ecu, anything else that is different due to auto? I would purchase a new R34 5 speed or CD00X 6 speed to accompany it.
Thanks!
Edited by TurboTapin
https://www.sau.com.au/forums/topic/482544-rb25det-neo-school-me/
1. Yes, it kinda is. In terms of differences, it has a different head, and a different block, as well as a different turbo and uh, different wiring and ECU, so I mean yeah it's a completely different engine (but also very similar.. paradoxically).
2. There's writeups about this, I would wager @GTSBoy will know.
3. No. In-fact you can re-use the Auto ECU/Loom for the motor in a manual car with no worries, and tune it with Nistune if you like.
1. NEO motors use solid lifters, however it's shim over bucket where as the RB26 is bucket over shim. Still good, but you need the correct tolerances if not when you kiss the limiter you'll shit out shims.
2. Wiring realy
3. Remove the auto spigot
Pretty much compulsory. It's the only way (other than an aftermarket ECU) to get the engine to run without emo fault codes about missing TCS, ABS, etc etc. Plus there's all manner of bullshit in the boost sensor & stuff that needs to be gotten rid of.
Search. Many many posts exist.
Thanks everyone for the quick feedback. I've searched but wanted a quick response from people knowledgeable in NEO's as I need to put an offer on it right now before it disappears. Wiring/ecu isn't an issue as it's in my line of work and I'm already familiar working with nistune.
Just wanted to confirm there's nothing mechanically funky with these compared to regular S1/S2 RB25DET's that would cause me any big issues.
Thanks again.
The throttle body does have a silly electronic blade on it which closes for 90s style traction control. Some of the Stageas didn't have them, so if you have one of these ones great! If not, weld the stupid thing open OR just run an aftermarket plenum/intake OR one off a R33.
6 minutes ago, GTSBoy said:
My TCS TB is still installed. Has never moved from the fully open position because there is no TCS CU installed to make it move.
I thought it would have closed (assumed default position), good to know it doesn't shut :)
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
