Hi forum,
First post. Are there people on this form, in Australia, who have swapped a V8 in their 350z, Nissan V8 or an LS motor? The stock VQ35 is amazing. Especially the in-cabin noise of even the stock exhaust sounds exotic—however there’s something really special and charming about a 2-seater sports car with a V8 engine and a manual transmission.
I’m also wondering if replacing the rear storage tub in the back of the 350 with rear seats out of the G35 (been done) would allow for baby seat installation. I mean how would one have anchoring points/ISO FIX in the rear of a 2-seater car?
Edited by Zb28
https://www.sau.com.au/forums/topic/482548-anyone-v8-swapped-their-350z/
It's probably the only way to make the Z33 & 4s palatable. The rest of us think that the VQ3X engines sound like complete arse. Nasty mooing V6 noise.
I was only thinking the other day of grabbing a cheap 350 to put an LS3 into. But then I realised that I also don't like the way that they look.
But yes. It's a good idea. Lots of fun** to be had trying to make the various electronics talk to each other though.
**ie, not fun.
  • Haha 1
friend did it with ls3 and blower was great but killed axels. Z's need a bit more go and they would be perfect.
new kit out that allows use of cd00* gearbox
https://www.lojkits.com/collections/nissan-350z-z33-engine-swap-kits
11 hours ago, GTSBoy said:
The only good sounding V6s come from Italy.
Dunno....I really liked the sound of the Ford Capri 3000 GT from the '70's.....and I'm no Ford fanboy, not even close.  But they did get that Capri right IMO.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
