ight so ive been in a pickle for while but i think im closer to pin pointing it, but i need help.
so a while back i started getting this warm engine misfiring, where once the engine reached running temp it would like cough, puff and basically shit the bed with shit response until it was undrivable, however the symptoms were far less noticeable when given a decent amount of open throttle and high revs funny enuff. (and when it was cold)
- since it shat the bed ive taken out the plugs twice, first time it smelt like fuel then the second time a month after the ends where white and crispy (got pics) probably worth noting the car wasn't seeing a whole lot of action the 2nd time the plugs were removed.
- ive found fuel in the intake manifold gasket when i took it off, and worth noting the inside of the plenum/mainifold was filthy AS HELL with a layer of oil/grease/37year old filth lining it.
- when i took off the rocker cover the shit is filthy as hell, good layer of grime on every thing, but the grim gets blacker the closer it gets to cylinder 6th, apart from needing an oil flush (dont think the last owner did one, after resurrecting it from a 10year sleep) it looks all good ish. i remember seeing a black spec on a cam lobe but it looked like it was ment to be there, but ive never seen a warn down cam so idk really.
ran a compression test and it pulled through great, all cylinder with 5% difference between each of each other
things ive replaced/checked:
- replaced AFM, ECU, leads, plugs and refurbished the distributor/CAS/ignition coil
- had the Throttle position sensor checked, injectors cleaned
did a fuel pressure test with my hand on the fuel lines and that seemed fine, cant rule this one out for certain tho
- gonna change the some of the connection to the dizzy, afm, and maybe injectors, but i dont think its electrical due to the nature of it only happing when the engines warm.
               ight so ive got a little hypothesis based on some research ive been doing
so in regard to this being based around the fact it misfires when its warm im thinking about blaming it on poor valve timing. Because from what i understand with an engine that require lash adjustment (rb30 doesnt i know) that a lower lash increases valve lift and duration, good for high end power at the sacrifice of low end torque. I also understand that the lash/gap is indented to compensate for metal expansion under heat. I know im going out on a limb but IF the hydraulic lifters 'seized up' and stared to act as a solid lifter with zero lash the symptoms would most prominent when warm, and with zero lash the open valve duration may be pushed to an extreme (opening to early and closing too late) MAYBE IF the intake valves closed late enuff they might still be partly open at the beginning of the compression stroke forcing puffs of air up the intake, bringing filth, oil and drying the spark plugs up.
( i know some of this seems far fetched(especially the second half), but ive replaced too many things), guess im just asking if theres someone with a bigger brain to correct me or give me some direction with this
cheers boys
That's definitely far fetched, and no way are you on the right track. It is physically impossible for that to happen.
Have you replaced the coolant temp sensor?  Or at least checked it?
  • Like 1
  • Thanks 1
^^^  or coil, bad grounds, alternator output voltage.
Its an electrical issue, resistance increases with heat. Get a multimeter and start testing.
Is this on a factory ecu?
  • Thanks 1
yeah i replaced that too, i think it actually does misfire a lot less or not at all when unplugged. ive forgot, tested that one a while ago
Edited by Cheww
yeah factory ecu. i dont have a ground on my extractors anymore surely it cant be that, so what do you recommend? checking for voltage on the ground wires?  not too familiar with electrical side of things but down to do my homework on it
Edited by Cheww
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
    • Yes, ther are plenty of [racist statement alert] terrifying 50+ yr old ladies of a certain ethnic origin who have no demerits yet still manage to park their cars on top of roundabouts, hanging out of multistory car parking structures and other wild shenanigans. Somehow they puddle through years of driving without ever attracting the attention of the cops, yet the whole time, they are an instant away from doing something spectactularly stupid.
