Reverse light are not even hooked up at the gearbox connector, and I don’t see any wiring at all,that indicate they could be for reverse light.  Which could have been deleted from previous owner.
 Researching through online, Figured out the reverse light wiring is part of this unwrapped harness in the photo.
Does anyone know which one are they ?
Also once I know the wires how should I proceed connecting them to the box ?
TIA
https://www.sau.com.au/forums/topic/482555-r32-manual-box-reverse-light-wiring/
Yea man tried looking into it, couldn’t figure out still. Only transmission wiring I found in that manual is the neutral switch and speedo.
If you know the page no. For whole transmission wiring, that be great.
Still don’t think it’be same for 20det box
The 20DET RWD box and the 26/20DET AWD box both have a reverse switch. The reverse switch wiring will definitely be on the diagram. I'm 2000km away from my copy of the manual, so can't easily look for you. Keep looking.
One is neutral, the other is reverse. You can actually work out which is which for yourself by probing them. One will be closed (short circuit) in neutral.....the other in reverse.
FWIW, on the small l box, I think the frontmost one is reverse and neutral is the rear one.
  • Thanks 1
OK, so, I downloaded the R32 GTR manual that's up on NicoClub's site. On the 3rd page of wiring diagrams (the last pages of the PDF), which I show here zoomed out for identification purposes
Right in the middle is the reverse lamps and the reverse switch (for MT vehicles)) is shown right there, just above it. I've zoomed it in and circled the area of interest, here
The wire that runs along the bottom of the reverse light is earth. If you follow it to the left across the pages of the pdf you will find it ends at the -ve symbol. On the way, it passes both the vehicle speed sensor and and the neutral switch too (as you scan along the diagram). I don't know if this means that there is a buss wire or if it the body earth, but it doesn't matter. This will become relevant later, when I describe probing.
It shows the wire colours, but sadly, this pdf is too low a resolution to be able to decipher them.
I have at least 2x pdfs at home, plus the paper copy that I photocopied myself from a manual I borrrowed from Nissan Australia last century. I'm sure that at least one of the pdfs I have (and my photocopy) have legible wire numbers everywhere.
So what I'm telling you is, find a pdf upload that has better quality (if the one you already have isn't good enough), and have a look at that section. The wire colours are shown each side of the switch.
But, there are still things you can do even without a legible drawing. You can use manual methods to probe the wires. Start with a meter connected to the appropriate side of the reverse lamp wiring in the boot (the side that goes back to the switch, not the earth side that I described above) and probe around the gearbox loom under the car until you find continuity. That should be one of the wires. Then, the other wire is known to go to IGN relay 2, shown on the next page of the pdf, with the interesting parts circled n the below image. That wire code circled is the lower wire of the pair that comes in from the left, which is the same wire that leaves the previous page on the right, having come through the reverse switch. You go find IGN relay 2 and you can identify the wire coming out the relay that delivers 12v to these circuits, and probe looking for continuity to wires in the gearbox loom.
As a further plus, the neutral switch should be 2 of the other wires in the gearbox loom. One of them will be earth and the other one will go back to the appropriate terminal on the ECU, which I think is 44, but you should double check with the ECU pinout.
Edited by GTSBoy
spellink
  • 3 months later...
I have recently brought a R32 that had been manual swapped it had no wiring running down to the tranny that is supposed to Be next to the fuse box in the engine bay, the reverse light switch is not hooked up and the only thing I see the old owner done right was bridge the inhibitor so the car can start, does anyone have photos of wat plug and pinout is used for the to wires on the reverse light switch :)
Also the 3pin plug in the middle wat is it for?
  • 3 months later...
@GTSBoy
thanks mate, been totally strapped at work didn’t get a chance to look up here, at the time rwc guy turned back, was too keen to see em reverse lights so did a bit of dodgy job wiring it straight from the box to rear lamps hahaha, and had him back and should have taken a photo of him smiling lol,
@Nathan rfb
Mate not too sure how different it might be on a auto loom,
green (grey dots)
green/white trace
was the wiring for me from the big connector next to the fuse box in engine bay area. Same has wiring for neutral switch green/o from memory.
If this doesn’t help, the MIGHTY METER worked out for me in the end.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
