I recently swapped my er34 back from a haltech elite with adaptor harness to the factory computer. Swapped all the sensors back to factory etc etc. Car idles no worries on the haltech, but will not even give a puff on the stock ecu.
Has spark, has fuel..
Any tips or ideas that come to mind would be greatly appreciated on what this issue may be.
Thanks
https://www.sau.com.au/forums/topic/482578-er34-factory-ecu-issue/
Thanks
What injectors are you running mate?
When you say ""not a puff" do you mean it cranks but doesn't try to fire?
I'd be checking the ECU has power, since it is back to stock can you plug a consult in to check? Or even just listen for the ECCS relay clicking in the passenger footwell as a start.
Correct it has the fuel pump prime and displays all lights on dash then cranks over no worries but doesn't fire.
I sadly have no consult system available. It makes all the normal clicks with the key turned to ignition as it used too strangely enough.
I believe the computer may somehow be dead. It's been sitting on the passenger floor untouched for about 5 months as the car sat with the haltech plugged in. (Car isn't on the road)
