I drive an R34, but it is not a GTR, so it doesn't have an OEM MFD. I recently ordered an MFD housing because I want to do a custom project with a monitor for a reverse camera. The OEM bezel has a curved transition that will take a bit more work than just a flat ABS panel, so I was wondering if anyone had successfully 3D-printed something, or has a file they wouldn't mind sharing.
i doubt anyone will share a 3d printing file as its not a straightforward part to produce and will take a bit of time to model up. Plus you could then start selling the parts
These guys had a go, but i believe they were having troubles so removed the product from their shop.
https://www.facebook.com/permalink.php?id=829003997303711&story_fbid=1415948455275926
I'm not after the whole cover. I purchased that new, OEM. Just the bezel that frames the screen. If that's what you meant, then I didn't see something like at 3D Racing Solutions. Just the whole cover.
And I understand that most people wouldn't want to share a file. But the general attitude of the post was mostly one of seeking information.
Ah sorry, i misread the post. if its just a bezel, it shouldnt be too hard to draw up if you can provide dimensions.
Might be worth downloading fusion360 and watching a couple of youtube videos then you can have a go at making the file yourself.
maybe cut up a bit of card to start with, measure it then tweak the curvature on CAD.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
