Hi guys, lately my V35 drift car has been hard to get into first/reverse when idling at a stop sometimes. I have tried adjusting the clutch pedal, giving it the maximum preload one way so it releases the clutch the most (just for testing) which doesn't help. I've since adjusted it back to its correct positioning so there is no preload on the pressure plate etc.
Also sometimes when letting out the clutch, I get a bit of vibration thru the pedal. I'm guessing the flywheel is a bit warped due to all the heat cycles from drifting it. I have bled the clutch system properly as well. Transmission fluid etc is all new
Any suggestions to help it, except for removing the flywheel and getting it reground?
Regards,
Blake.
https://www.sau.com.au/forums/topic/482646-hard-to-get-into-first-gear/
I had these symptoms in my old R31 skyline year ago, turned out the clutch plate had failed (and was nearly worn down to the pins.
Toward the end I had to put it in first and start the car, because I couldn't get it in 1st with the engine running.
Single or twin plate?  From what I have read and been told by mechanics.  The V35s chew twin plates to dust really fast.  Getting mine replaced right now.  It should be noted that my twin plate clutch has only done like 16000kms from new.  I barely ever drive my V35.  It spends more time in the shop than with me.  The single plate lasted over 110000kms
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
