Hi, so my series 1 r33 GTST's AC decided to die in California's hot summer. I've been finding replacement parts and its been a nightmare. I've been thinking of rebuilding the ac but I heard its pretty expensive and It's hard to find a place here in san Francisco. Does anyone here have experiences or alternative to fixing the compressor?
I recently went through this with my w34 stagea and was unable to find new genuine or aftermarket options. I ended up taking a punt and buying 2 used ones off yahoo japan, and the first one I fit worked so I have a suspect spare.
I suspect AC compressors are going to become one of those impossible to find parts over the next few years until someone works out a non genuine alternative including mounting
On 21/07/2021 at 1:37 AM, White GTS-T said:
Hey,
Sorry to hear, I'm not trying to be a dick, but do you know that it is a compressor failure, or are you just speculating because your A/C isn't working?
Well, the clutch is apparently not engaging at all and has a huge gap, it also does have an activating click when turning on the ac. But regardless the compressor needs to be changed anyways
Yahoo auction is actually a pretty good idea. do you know if stagea's compressor will fit the gtst?
Edited by Honeyboost
Possibly...there were differences across R33 air cons and I'm not sure what they were. Late R33 and Stagea are *apparently* the same.
The mounting is the same, the wiring is either the same or interchangeable (1 wire) but the fittings to the car can vary.  I'm sure others know better than me.
You can confirm the exact part# using your VIN through FAST or parts websites.
Clutch <> compressor. Compressor could be fine. Probably is. The compressor and clutch are going to be common with other cars. Take it to an auto electrician, particularly one who also does air-con regassing etc.
And how can it be hard to find someone is San Fransisco to rebuild a compressor? I live in a backward city in a backward country where we all hang upside down from the ground, with a population of only a million or so people and I can probably come up with a list of 5 or 6 places that I would be able to get an air con compressor done. You have SF (pop 1M, LA (pop ~4M), the rest of California (~40M), every other city on the west coast, every city everywhere else in a country with 300 million people.
  • Like 2
you're right, I might've not looked hard enough, I will do that this weekend when i'm free of work
It is possible the clutch isn't engaging because the air gap is too big. The clutch air gap is adjustable. The clutch air gap is determined by a stack of shims of varying thickness. You can change the air gap by changing/removing shims. You also need to be sure the clutch coil magnet is getting 12 volts when you turn your A/C on. And you need to put a set of manifold gauges on the system to see what it is doing. If the gauges indicate the static pressure in the system is okay, and you are getting 12 volts to the compressor and the clutch air gap is within specification, then and only then can you rule out the compressor while watching the gauges. Hope that helps
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
