Hi, so my series 1 r33 GTST's AC decided to die in California's hot summer. I've been finding replacement parts and its been a nightmare. I've been thinking of rebuilding the ac but I heard its pretty expensive and It's hard to find a place here in san Francisco. Does anyone here have experiences or alternative to fixing the compressor?
I recently went through this with my w34 stagea and was unable to find new genuine or aftermarket options. I ended up taking a punt and buying 2 used ones off yahoo japan, and the first one I fit worked so I have a suspect spare.
I suspect AC compressors are going to become one of those impossible to find parts over the next few years until someone works out a non genuine alternative including mounting
On 21/07/2021 at 1:37 AM, White GTS-T said:
Hey,
Sorry to hear, I'm not trying to be a dick, but do you know that it is a compressor failure, or are you just speculating because your A/C isn't working?
Well, the clutch is apparently not engaging at all and has a huge gap, it also does have an activating click when turning on the ac. But regardless the compressor needs to be changed anyways
Yahoo auction is actually a pretty good idea. do you know if stagea's compressor will fit the gtst?
Edited by Honeyboost
Possibly...there were differences across R33 air cons and I'm not sure what they were. Late R33 and Stagea are *apparently* the same.
The mounting is the same, the wiring is either the same or interchangeable (1 wire) but the fittings to the car can vary.  I'm sure others know better than me.
You can confirm the exact part# using your VIN through FAST or parts websites.
Clutch <> compressor. Compressor could be fine. Probably is. The compressor and clutch are going to be common with other cars. Take it to an auto electrician, particularly one who also does air-con regassing etc.
And how can it be hard to find someone is San Fransisco to rebuild a compressor? I live in a backward city in a backward country where we all hang upside down from the ground, with a population of only a million or so people and I can probably come up with a list of 5 or 6 places that I would be able to get an air con compressor done. You have SF (pop 1M, LA (pop ~4M), the rest of California (~40M), every other city on the west coast, every city everywhere else in a country with 300 million people.
  • Like 2
you're right, I might've not looked hard enough, I will do that this weekend when i'm free of work
It is possible the clutch isn't engaging because the air gap is too big. The clutch air gap is adjustable. The clutch air gap is determined by a stack of shims of varying thickness. You can change the air gap by changing/removing shims. You also need to be sure the clutch coil magnet is getting 12 volts when you turn your A/C on. And you need to put a set of manifold gauges on the system to see what it is doing. If the gauges indicate the static pressure in the system is okay, and you are getting 12 volts to the compressor and the clutch air gap is within specification, then and only then can you rule out the compressor while watching the gauges. Hope that helps
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
