Got a 2004 v35 that we are about to put up for sale. It’s passed everything for a roadworthy except the following on the front suspension:
-upper ball joints
-lower ball joints
-tie rod ends
-lower control arm bushings
As a bit of a noob, having trouble trying to figure out exactly what parts to order (trying to minimise cost as it’s being sold). The labour will be done by a mechanic though.
Two places have told us it’s better to just replace the whole control arm vs trying to press in new bushes. Is this the case? And does this apply to the ball joints to? Best I can tell, the upper one connects to one of the arms, and we’ve been told you can’t press new ones in.
Thanks!
Seems a bit convenient that all those things need doing at once.  I would be seeking a 2nd mechanic to double check them for you.  Especially since they haven't mentioned the compression rod bushing, which seems to be the most common failure point in the front suspension.
But if you need to it all, you can replace the LCA bushes separately, can't get genuine bushes, only aftermarket, but should be quite a bit cheaper than the buying the whole LCA.  Upper ball joint is part of the whole upper control arm, so would need the whole arm.  There are 2 lower ball joints on each side, one in the steering knuckle which is replaceable and one in the compression rod, which requires replacement of the whole compression rod, so you would need to determine which one they are saying is bad.
We’ve got photos from the roadworthy which show the damaged bits, and that was our second opinion, the first said the same thing.
Thanks for the info re the upper arm.
Looking at the lower arms, they seem to come with either a shallow or deep ball joint nut recess depth…anyone happen to know which is correct? One place has said the deep but we’re not 100% sure and the only way to tell is by taking it off. The car is a 2004 350GT coupe, with the leather seats.
wasn't even aware there was a difference, but it seems they are right, the series1 V35 appears to be part number 54500-AM601 and 54501-AM601.  But the Series 2/3 is 54500-AM602 and 54501-AM602.
These pictures may help -
https://conceptzperformance.com/nissan-infiniti-nissan-oem-front-lower-control-arm-link-03-04-rh-nissan-350z-infiniti-g35-54500-am601_p_6928.php
https://conceptzperformance.com/nissan-infiniti-nissan-oem-front-lower-control-arm-link-rh-nissan-350z-05-08-z33-infiniti-g35-05-06-sedan-05-07-coupe-v35-54500-am602_p_6927.php
Edited by sonicii
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
