Hi, I have a problem with my 91 R32 GTR. I usually am able to find answers through old post but I can not find one like this. Car is running an Apexi ECU. When the car is warm about 5-10 minutes of driving it will start not reving and pulling to redline. It is like a rev limiter at like 5500rpm or sometimes 4500rpm. The longer I drive the lower the limit goes under load. If I stop and shut the car off for a few minutes. When I start it back up it will pull to redline like normal. Then few minutes later back to limp mode or something. I have already cleaned and soldered the MAFs. Just cleaned the coils packs and dielectric greased them. I was wondering if anyone else knows where I might look for my issue. When it starts cutting out it does not backfire or cause the car to buck much at all. It is like the car just shuts off. Going to replace the fuel pump soon. After that I am not sure if I should be chasing a bad ground down or what.
https://www.sau.com.au/forums/topic/482679-r32-gtr-loss-of-power-when-warm/
Nothing out of the ordinary. Well with what I can see on the hand controller. No weird high knock or voltage drops. It will still boost normal but then it does what it has been doing. I will have a new pump in it in a few days. If that doesn't help I think I will look at the connections on the ecu and wires. I will probably check for boost leaks which I don't think I have. Seems like something that resets after the key is turned off and back on. Car has new plugs and injectors. It ran fine for a while then I let it sit in storage for a while and been chasing random little issues.
The igniter modules have a habit of misbehaving when they get old and hot. Can  you borrow a known good igniter from someone. (if you are in Melb west subs, I have one you could borrow)
I finally figured it out. Well one of the few things I did fixed it. Went for a 30 minute drive and never messed up. I believe it was the fuel pump. I ordered a new one before I took my old one off. The old one was really rusty, and the sock was very dirty. So I cleaned it all up and cleaned the connections on the pump. Decided to throw it back in while I waited for the new one and drove great. I also replaced a fuse in my viper security system that was blown and then I cleaned up the battery terminal. I was just grasping for straws but think it was the fuel pump not getting enough fuel. Thanks for the help.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
