elohim_imanu Posted July 31, 2021 Share Posted July 31, 2021 Just put in a brand new RB25DET big box, auto conversion. Last time I drove manual was my 260Z, 15 years ago. But this box seems a bit notchy shifting up. Are new gearboxes like this? Do they have a break in period? Also noticed a vibration on the clutch pedal when shifting close to red line. It is R34 box, with a pull clutch. I installed a new Nismo sports clutch with a slightly lighter flywheel. I am running Penrite Pro Gear 75W-90. Cheers Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/ Share on other sites More sharing options...
Duncan Posted July 31, 2021 Share Posted July 31, 2021 Yes, a brand new box needs to wear in a little, and the "big box" is actually pretty beefy compared to most. Just treat it nice for 500klm then change the oil, see if it improves 1 Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7954402 Share on other sites More sharing options...
Torques Posted October 6, 2021 Share Posted October 6, 2021 Just wondering, what is a 'big box' ? Cheers Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956530 Share on other sites More sharing options...
Duncan Posted October 6, 2021 Share Posted October 6, 2021 That is what the bishop said to the actress. Or, just the physical distinction between rb25 and rb20 boxes which have smaller/weaker gears Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956537 Share on other sites More sharing options...
elohim_imanu Posted October 6, 2021 Author Share Posted October 6, 2021 Or to be a bit more specific. The 5 speed gearboxes that are built to take the RB25DET (turbo engines). The R33 GTS-T and the R34 GT-T came with them. Also the 300ZX Twin turbos, came with a similar gearset. A modern version is the CD009, which comes on the 350-370Z, 6 speed. They physically look stronger better made with extra gussets etc. Basically these are the go to gearbox for people wanting a reliable gearbox for high HP applications. By the way I had mine checked by a local mechanic and he thinks it is fine, just needs some more miles to be clocked up on it. The vibration was due the the Nismo pressure plate being out of balance. Had to pull it out and get it balanced along with the brand new billet steel flywheel. I would have thought they should be good from the factory already. Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956539 Share on other sites More sharing options...
GTSBoy Posted October 6, 2021 Share Posted October 6, 2021 They're called the big box because they are physically twice the size of the little box. Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956544 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 7, 2021 Share Posted October 7, 2021 (this is my opinion, please feel free to ignore) whatever you do, don't put Redline Shockproof into the box. Great for old, worn and thrashed boxes - has no place in new tight boxes. Gee.. that sounded wrong. 1 Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956556 Share on other sites More sharing options...
elohim_imanu Posted October 7, 2021 Author Share Posted October 7, 2021 I am running Penrite 85-90 full synthetic. He reckoned I should not play with difference oils. As I saw someone comment that they think the synchro's in these like mineral oil more. 1 Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956561 Share on other sites More sharing options...
alexj Posted October 7, 2021 Share Posted October 7, 2021 Googling it, it looks like penrite do both a GL5 and a GL4 version. Apparently the GL4 is the one you want. 1 Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956575 Share on other sites More sharing options...
BK Posted October 7, 2021 Share Posted October 7, 2021 You beat me to it while I was typing this. Regarding mineral, Duncan mentioned somewhere in another thread about Terry at Award diff and gearbox recommending mineral with more frequent changes. I can definitely see the merit in that, getting rid of any excess metal in the box frequently. The same recommendation of changing gear oil after every event is for the same reason in dog engagement transmissions, to purge the metal shavings, regardless of oil type used. Obviously dog boxes shed more metal that synchro boxes but idea is the same for prevention of gear pitting and whatnot. The main advantage of using synthetic is the higher operating temperature break down point of lubrication, leading to longer interval changes which can be good or bad depending on how frequently you change transmissions oil. We generally break in / flush the synchro boxes with Castrol VMX-M mineral. Actually in our white 32 it still has it in it after 2500km including a 1500km drive to Adelaide on a rebuilt box and the shift quality is excellent. On 07/10/2021 at 1:36 PM, elohim_imanu said: I am running Penrite 85-90 full synthetic. You mean On 31/07/2021 at 7:32 PM, elohim_imanu said: I am running Penrite Pro Gear 75W-90. If so I hope it's this one Not this one, it's GL-5 On 07/10/2021 at 12:46 PM, Dose Pipe Sutututu said: (this is my opinion, please feel free to ignore) whatever you do, don't put Redline Shockproof into the box. Great for old, worn and thrashed boxes - has no place in new tight boxes. Gee.. that sounded wrong. I wanted to both like and laugh at that one 😄 Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956576 Share on other sites More sharing options...
elohim_imanu Posted October 7, 2021 Author Share Posted October 7, 2021 Actually I mean this one, after a check. (the 90 was for the diff) 🤣 Is this bad? I was surprised to see the amount of tiny steel shavings when I drained it after about 150ks, due to the clutch balance problem. Since I do not race and I am not pumping high HP through, it is this oil a good choice and how often do I change it? We are only talking a few thousand ks a year. Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956578 Share on other sites More sharing options...
BK Posted October 7, 2021 Share Posted October 7, 2021 Nah should be spot on 👍 Your box is new yes ? It will shed a fair bit from new, a balance problem wouldn't have had an influence on gear to gear mesh, which is where most if the material comes from. Change intervals ? Change it in a year and see what it looks like. When new a good 500 -1000km first oil drop is generally the go. 1 Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956579 Share on other sites More sharing options...
BK Posted October 7, 2021 Share Posted October 7, 2021 As long as it wasn't this one in 75w-85 your good. Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956585 Share on other sites More sharing options...
Torques Posted October 7, 2021 Share Posted October 7, 2021 Ok, thanks ... I'll open a separate thread on my question. Link to comment https://www.sau.com.au/forums/topic/482681-brand-new-rb25-big-box-notchy-shifting/#findComment-7956598 Share on other sites More sharing options...
