Hello,
During highway around 3000rpm I'm at around 840 in sixth gear.
During a WOT second gear to 4th gear I'm at 960 and I stopped at this point... (MFD starts to warn me)
Engine iddling I'm at about 550
I didn't pay attention in the past to this as I was solving others issues...
The car is fully stock, everything seems to work good
It looks like the engine is running too much lean ? Should I make some log data for the AFR ?
I suspected the fuel regulator and the fuel pump to be 22 years old....Is it probably the issue ?
THanks for your inputs
https://www.sau.com.au/forums/topic/482685-stock-r34-gtr-high-egt/
I had this issue and it turned out to be massively wrong timing making the exhaust valves open too soon. The tuner had seen too many rb26s of all kinds and I think they forget what stock is supposed to be like. They just said to me dont worry about it, metal doesnt melt at that temp.
timing probably isnt your problem just saying that you know best that it has changed, so get to the root cause.
So I try to set the ignition to 15,20 or 25 doesn't make any difference..
I have 2.6 bar at iddling on the fuel pressure line (taken after the fuel filter)
I have 3.0 bar when removing the vacum hose or during the next 5secs I put the ignition on
The fuel pressure is between 3.0 and 3.5 bars under WOT
The fuel pressure is droping slowly continuously a bit after I switch off the car
According to the service manual, these values are ok meaning pressure regulator and fuel pumps are ok
I don't know what to do/test...
The car is fully stock, seems to be in good health (no suspect sounds or lack of power )
Any suggestions ?
Man, adding a Heap of timing is a brave move. I hope there was no WOT action while doing that test
  • 3 weeks later...
Thanks for all your input guys
It looks like the exhaust cam timing is wrong ...(1 teeth off )
However when putting the engine at its top dead center
the admission cam is 0.5 teeth off and so the exhaust cam is 1.5 teeth off
Does it means that the timing belt pressure is wrong which explains the 0.5 teeth difference?
Thanks for your time
On 9/5/2021 at 2:26 PM, bigboss59400 said:
So end of the story
by setting correctly the timing belt everything Line up correctly
The car is now running much better !!!
I couldn't go above 800 degree on medium/hard road drive
I'm so happy
thanks for all
You should probably verify your base ignition timing and do a compression test before you celebrate.
  • Like 1
  • 1 month later...
Yeah I
So to conclude compression test is between 100 and 105psi (full throttle, battery charged )
I always noticed that the high rpm didn't felt powerful
So maybe it has been damaged due to the high temp or not
Anyway it's fine for me at the moment I will leave it as it is
Thanks for the help and suggestions !
