Hello,
During highway around 3000rpm I'm at around 840 in sixth gear.
During a WOT second gear to 4th gear I'm at 960 and I stopped at this point... (MFD starts to warn me)
Engine iddling I'm at about 550
I didn't pay attention in the past to this as I was solving others issues...
The car is fully stock, everything seems to work good
It looks like the engine is running too much lean ? Should I make some log data for the AFR ?
I suspected the fuel regulator and the fuel pump to be 22 years old....Is it probably the issue ?
THanks for your inputs
https://www.sau.com.au/forums/topic/482685-stock-r34-gtr-high-egt/
I had this issue and it turned out to be massively wrong timing making the exhaust valves open too soon. The tuner had seen too many rb26s of all kinds and I think they forget what stock is supposed to be like. They just said to me dont worry about it, metal doesnt melt at that temp.
timing probably isnt your problem just saying that you know best that it has changed, so get to the root cause.
So I try to set the ignition to 15,20 or 25 doesn't make any difference..
I have 2.6 bar at iddling on the fuel pressure line (taken after the fuel filter)
I have 3.0 bar when removing the vacum hose or during the next 5secs I put the ignition on
The fuel pressure is between 3.0 and 3.5 bars under WOT
The fuel pressure is droping slowly continuously a bit after I switch off the car
According to the service manual, these values are ok meaning pressure regulator and fuel pumps are ok
I don't know what to do/test...
The car is fully stock, seems to be in good health (no suspect sounds or lack of power )
Any suggestions ?
Man, adding a Heap of timing is a brave move. I hope there was no WOT action while doing that test
  • 3 weeks later...
Thanks for all your input guys
It looks like the exhaust cam timing is wrong ...(1 teeth off )
However when putting the engine at its top dead center
the admission cam is 0.5 teeth off and so the exhaust cam is 1.5 teeth off
Does it means that the timing belt pressure is wrong which explains the 0.5 teeth difference?
Thanks for your time
On 9/5/2021 at 2:26 PM, bigboss59400 said:
So end of the story
by setting correctly the timing belt everything Line up correctly
The car is now running much better !!!
I couldn't go above 800 degree on medium/hard road drive
I'm so happy
thanks for all
You should probably verify your base ignition timing and do a compression test before you celebrate.
  • Like 1
  • 1 month later...
Yeah I
So to conclude compression test is between 100 and 105psi (full throttle, battery charged )
I always noticed that the high rpm didn't felt powerful
So maybe it has been damaged due to the high temp or not
Anyway it's fine for me at the moment I will leave it as it is
Thanks for the help and suggestions !
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
