Hey Guys,
So i'm finally getting around to rebuilding my AWD RB25DET NEO.
I haven't rebuilt an engine before.
I have bought a genuine Nissan RB25DET NEO complete engine gasket repair kit (part number: 10101AA525).
So I have worked out the sump and water pump need a fluid gasket.
Kit instructions say sump needs a 4mm bead of gasket, while other areas require a 2.5mm bead.
Just wondering what other areas need fluid gasket?
Thanks in advance
Brendan
On 8/7/2021 at 11:31 AM, GTSBoy said:
Corners of cam seals under the cam covers. Little squidge of goo there helps to prevent leaks. That's about it.
Thanks
Not too long ago I used to think every gasket, including head gasket had some on it.
So none on thermostat?
I spose those half moons on the cam cover need some?
You can spooge the thermostat gasket, but it will seal with just a paper gasket. After all, cars have all done that for the last 100+ years.
Cam seal corners and half moons all much the same. Not required, but a little can prevent later weeps developing.
  • Like 1
