On 20/08/2021 at 10:24 PM, BourneToLive said:
I had already installed the ballast delete with the injectors. And I did research on the changes to Injector duty to compensate for the bigger injectors yesterday and gave it a shot. I set it to 52.1% at 0.06 and it stalled out any time I came to a stop, so I set it to 74.1% instead and it fixed that issue. Although, since my last tuner tuned the ECU to work with the 555cc injectors, I based my calculations on the previous injectors and came to ~64%. 48% turns the car and then shuts off immediately.
If that's the case your existing tune is really really bad. You don't base the setting on what you already have - 100% represents 440cc and the setting change is done from there, end of story. I used to run Sard 1000cc EV1 injectors with zero idle issues with short pulse width on a D jetro power fc - setting for these were 44 - 45%.
If you are needing to be higher % you are just rescaling your entire fuel map richer.
You need to get on the dyno for a tune badly. Without a wideband it's all pointless.
  • Like 1
I second this. Please get a wideband or throw it on a dyno with a decent tuner.
Nah. You've got the tuning tool (the handset). Buy a wideband instead, use that to adjust the injector settings until you've got the scaling right (for the top end) and the dead time right (to get the bottom end right). Should only take a few minutes on the road with 2 people. Err on the side of rich at the low end, and aim for ~11.5:1 at higher loads. You just need to be cautious in how much load you put on in case it is lean when you start - but you can almost certainly set the scaling to where you know it is both able to run and quite rich from the various values you quoted earlier.
Then, assuming your original map has the cruise and transitions sorted out, you should be gold. The wideband will tell you whether it's any good or not.
On 8/22/2021 at 11:09 AM, BourneToLive said:
I just found this picture from when my tuner tuned my car. I’m not good at reading these things.
Is there something you wanted explained or was there something you were curious about?
There are plenty of resources out there if you want to learn about fuel or timing maps etc.
On 8/19/2021 at 7:51 PM, BourneToLive said:
I took my car to a tuner today and he said the injectors are too big for the PowerFC to handle. Told me to get a better ECU.
Should be no worries im sitting on the dyno now  in a GTR with a powerfc and the same injectors, im happy to do up to 2200cc's.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
