Hi all bare with me on this one.  I have a project I want to have a nudge at but I don’t want to go into to much detail as I’m 99% it hasn’t been done yet. My question is as silly as it sounds is can you change what side the exhaust and intake port are on? eg. change it from exhaust on the right side of the head to left hand side and the same for the intake.
one would assume a custom cam would be needed to get the exhaust and intake lobes in the right place
im asking on here as I don’t have a head or the experience to work it out and collective knowledge always seems to work
 Cheers
lucas
https://www.sau.com.au/forums/topic/482718-rb25det-heads/
I would say that that is a hard no. The shapes and sizes of the intake and exhaust ports are quite different, and you don't necessarily have the room to hog out the (small) exhaust ports to approach the size of the intake ports because the water jackets are quite close to the exhaust port walls.
Then you would have to look at whether it would be possible to fit intake sized valves where the little exhaust valves come from (which would require removing a lot of metal and you'd probably face a similar problem with water jacketing there) and then you'd have to close up the inlet valve holes to take smaller valves.
Just use a 1JZ.
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954666
On 8/9/2021 at 6:14 PM, Dasmbo said:
You can do what i did send your head to Lewis engines and get it machined to suit your purpose it cost me about $4500.00 and it makes one hell of a difference
You swapped the sides of the inlet and exhaust manifolds?
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954682
Yeah, nah sweetheart. We'd be talking about $20+k of work here and it still probably wouldn't work.
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954685
I'll do it for $19,999 and bore it out to a 4L at the same time.
Heres one i did earlier this week
Product Overview: Ford Barra 4.0L Terminated Engine Harness - Haltech
  • Haha 1
https://www.sau.com.au/forums/topic/482718-rb25det-heads/#findComment-7954688
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... 😛
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. 🔹 Initially, he quoted me $3,500 - $4,500. 🔹 First invoice: $5,315 (already above the quote). 🔹 Second invoice: $1,375. 🔹 Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like I’m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! 🙏 Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
