Hey all!
going from pink label to r35 maf when my stagea goes for a tune. Running nistune.
just wondering if i should go through the extra effort of wiring the maf into cooler piping or put it in the 4 inch intake? Car will have no BOV and max flutter so not sure if thatll affect it.
expanding on that! If in either location where in the piping should the sensor go?
Edited by 33bus
https://www.sau.com.au/forums/topic/482721-r35-maf-into-rb25det/
I have an R35 maf in a 4" draw through setup with straightener. It was a nightmare to tune around idle and decel and it's still not 100% perfect. If I was keeping this setup (It's coming out this winter) I would redo it.
I should have went 3.5" blow through from the start.
Cheers.
  • Like 1
On 10/08/2021 at 10:04 PM, GTSBoy said:
hectic flutter will make tuning harder.
still easier than a Z32 :)
Dirty workaround, set the decel timing like all around 25~30 just before idle. Stops it stalling, but yes it's a dirty workaround.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
