Just got my car back from the paint shop and couple people on the road told me my brake light was out. Turns out the running lights all light up, but if I have no lights running and I tap the breaks the passenger side middle bulb doesn’t light up. Also if I have the daytime lights on, the passenger side tail light is brighter than the others.
https://www.sau.com.au/forums/topic/482725-tail-light-issue/
Thought so. Reason I ask is if it was OK before, clearly there is a globe issue now. Your left brake light is coming on with the tail lights. They are a dual filament globe, so it's probably either correct globe not seated correctly or an incorrect single filament globe someone has put in there that shouldn't.
Or the worst case it's a wiring issue, but how would we know as you haven't even checked if the correct globes are in there for a start - go have a look and then report back.
On 8/11/2021 at 10:04 PM, BK said:
Thought so. Running Reason I ask is if it was OK before, clearly there is a globe issue now. Your left brake light is coming on with the tail lights. They are a dual filament globe, so it's probably either correct globe not seated correctly or a single filament globe someone has put in there that shouldn't.
I took the back out and turned the running lights on and the middle bulb does not light up.
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
