How awesome is this. Good work. I love the carbon mufflers.
About the welding, what gas are you using? You obviously know what you are up to...but if you are using a TIG then with an Argon shielding and purge gas you get an even neater weld with less heat input. Get some Varigon shieldign gas and use an argon purge and the weld is even better again as the gas burns hotter and stops oxidation of the weld pool.
Apologies if you know this already, but my welding fetish is only matched by my brake fetish
...oh and not on twin setup like this from Japan, do they ever run a balance pipe in the exhaust like all the Corvette (ie big V8s) do?
had to fit a couple of hotdogs in it to shut it up a bit.....no stainless ones in stock so i fitted steel ones to see if they would work how i wanted..... and they do so i have ordered some stainless ones...the steel ones were 70 each the stainless 150.....i figured i could afford to risk 140 to see if it works other than finding out 300 worth of dogs were going in the bin....
so you decided against having the mufflers angled? It looks as you went to quite alot of effort to get both tips pointing straight back. I mean maybe it could have been easier to have them angled as now one of the pipes has a 90 degree bend where it loops around the diff. Maybe not so good for flow...
the under body wont allow it(spare wheel well,hangers no clearance to run the pipe under the suspension craddle cant fit the diffuser back on if its done any other way...and the list goes on...)and its not what i wanted anyway....
oh i forgot the diffuser, i guess your right then :)
As long as it sound good :)
Not sure what you mean by 350Z style..... I will post more pics of the system as it get fabricated....i think we should wait untill you get your car...then we will do the match up as i am not to keen on playing with same one elses bumpers(neither would they be :D)...dont worry too much about it chinny...we will get them to fit nicely
350Z Style? like M3, pipes both side of the car, but from your pics i know what you're doing now.
Whatever you think is best, i did have someone willing to lend their R34 (hi Bass Junky!) but you'd still rather use my car?
ok, so you think it can be done then? Cos the initial line up was just too see if it was plausible and i'd go and get a GTR rear bar after if you thought it could be done? Because if you think it's the way to go (rather than try and mould something) i'll go and get the rear bar from someone who has one here in Melbourne.
cheers.
  • 2 months later...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
