I'm putting together my RB30/26 build.
What's supposed to go in this hole, and where do I find it? Looks like an oil orifice or something.
I've searched a bit, and can't find it in the manual. A part number would help immensely. Also wondering if I can pull that part off an RB26 block.
https://www.sau.com.au/forums/topic/482766-what-goes-in-this-hole-rb30-block/
Just had a quick look an the RB30 block in my shed - that hole is either blocked with a solid plug of some sort (not a welsh plug), or it isn't actually a hole, just a slight depression in the casting - it's hard to tell.
  • Like 1
I don't have a block handy, but I expect it is access to an oil gallery for cleaning, and therefore needs to be plugged again after machining and cleaning. There is no external feed there.
Also, be aware there are other plugs that have probably been removed during cleaning, in particular the one under the oil filter housing that will allow all the oil to drop back to the sump if it is missing....
That helps. Thanks.
Yeah, looks like it's an oil passage, and the block was cleaned before being built.
The one under the oil filter housing: Is that accessible from the outside, or only by taking the sump off? I've got a PRP prepped block and it came with the PRP block brace/AWD adaptor already installed...
Thanks for the help!
On 8/27/2021 at 11:58 PM, GeeDog said:
Had a look at my other RB30 block and it is definately a plug of some sort (ignore the rust, this block has too many holes in it and is out in the weather):
I'd guess that's hammered in since there's slot or hex key to pull it out... Hmm.
Consensus seems that I can just measure the threads and plug it with a grub screw of some sort, eh?
Thanks guys. I appreciate the help.
Unfortunately I don't have clear pictures, and this is for an RB26, but this is all of the oil and water plugs in the block according to FAST
Every shop will clean a block differently and some may put none (or worse some) of the plugs back. The welsh plugs are pretty obvious if they are missing, although there is a trickier one in the back of the head above where oil drains are often attached.
Checking the one under the oil filter housing requires removal of the filter mount and I think there are some differences for rb30 with how the filter mounts. The RB30 I have in the stagea has a stagea oil filter mount so I'm not sure of the standard setup.
Main oil gallery plug.
They’re just an alloy punch in block off bung.  I threaded my holes (there’s one each end of the block) but you need to be very careful to not go too deep with your bolt as one of the head supply or main bearing galleries (can’t remember which…) comes off that passage quite close to where the bung goes in.
  • 4 weeks later...
Quick update for future searchers:
The RB26 plugs (11021AA) did not work for my RB30 block. My RB30 has threaded holes, and the RB26 plugs are pressed in for a compression seal.
I was able to order the correct threaded plugs from Platinum Racing Products. Turns out my machinist had a few laying around as well though.
  • Like 1
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
