Hi.
I know i can get a custum one but i can get very cheap some HKS ones...problem is?
Has RB20DE NEO same exhaust like RB25DET NEO? I mean from cat to the end.
Something like this https://www.nengun.com/hks/hi-power-409 the R34 25GTT 2Door one?
Or are exhausts completely different?
Thank you 🙂
https://www.sau.com.au/forums/topic/482780-which-exhaust/
Buy two fat muffler and get an exhaust shop to make a custom one up for you.
You can buy a turbo cat back but it will sound as good as a fart cannon, so better off going to a parts store and buying a fart cannon and installing that instead (cheaper).
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955319
Hi,
Thank you for the answers :-)
I send message to nengun about that exhaust and sadly it wont fit(plug an play).
But i can buy the end of the HKS muffler and rest of it i can do with custom :-)
I know it is a long shot but this sound is nice.
Anyone try to guess what this should be? Sounds exactly how i want it. I try to message the guy but he do not reply :-/
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955331
On 8/31/2021 at 4:39 PM, Kapr said:
Hi,
Thank you for the answers 🙂
But i can buy the end of the HKS muffler and rest of it i can do with custom 🙂
Anyone try to guess what this should be? Sounds exactly how i want it. I try to message the guy but he do not reply 😕
Just sounds like an NA RB. Just like an NA RB.
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955339
@GoHashiriyathank you i will check them out 🙂
@GTSBoy yeah i know but with custom exhaust...the stock NA RB(with stock exhaust) do not sound like that 😕
I know just from the sound only...but i was curious if any would guess what type of exhaust it is(muffler delete or straight pipe etc)
IMHO it sounds like Silent type 🙂
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955348
Just to back GTSBoy up here, what OP is hearing is a placebo. Mufflers don't REALLY (they do a little, but honestly not much) change the sound of any exhaust, though they do change the volume.
ALL RB's sound similar. Indistinguishable. You'd get more difference out of changing the cams, or manifold, which noone really does. (for purely sound reasons). It comes as a byproduct of turbo/performance which aren't the issue here.
Sometimes there's not a lot of search results because it became kinda self apparent 18 years ago. The differences you're likely hearing between videos etc are far more likely to be mostly caused by the quality of the recording equipment and how that's been setup.
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955392
@Kinkstaah I know about the different sounds and quality but this is the only "good" one with same engine as mine.
I do not know what he has in that car but from many videos i saw it should only be the exhaust.
I have the "boring" twin stock and that not sound like that.
Sadly i cant just try different cuz as you know...GTT let alone GTR have different type and far as i know iam the only one in the country with this type of a car(R34 with RB20DE NEO).
Best i can do is to buy HKS but only the rear muffler (for the looks) and rest will be custom made.
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955394
There are literally thousands of different types of mufflers available on the internet. One being branded hks isn’t going to be any better then one branded magnaflow for example
forget buying a branded one. Just go to the local exhaust shop, tell them the size of exhaust and style of muffler you want and that’s the end of the story
listening to different videos will sound different depending on what sort of device you are watching it on,( mobile, tv, sound system etc) the quality of the device used to record said video.
  • Like 1
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955396
For the OP's purpose, yes just get any decent muffler you can afford, doesn't have to be JDM fanboi brands.
In reality the sound can slightly differ between them though.
Quality of packing, How the packing is wound, Type of packing (Fibreglass wool, ceramic wool, stainless wool) can change the sound of a muffler. Hell, even the size and shape of the perforated tubing inside the muffler can change the note. Some are high pitched, some are deep and smooth, and some will blow the ass end out when you 2step limiter at the local cars and coffee.
Personally for a Non turbo, try find one that has a smooth deep tone, which would be your large oval shaped mufflers like Magnaflow, Xforce etc. The fart cannon will sound shit.
Edited by djvoodoo
adding info
  • Like 3
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955398
  • 3 months later...
On 07/12/2021 at 5:29 AM, Kapr said:
Hi...dont want to start a new topic so i ask "again".
Is anyone know if 25GT(RB25DE NEO) has same exhaust as GT(RB20DE NEO)?
I saw that i can get Kakimoto Hyper Full Mega N1 exhaust but it is only for 25GT. Model number is N31354.
Thanks for the info 🙂
It should bolt up fine, personally for na I think the stock exhaust is the best, it's just more noise & usually not a nice noise & doesn't go any better
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7958500
interestingly (or not) the biggest change in exhaust note that I have found, apart from changing from the stock exhaust obviously, was changing to Supertech valve springs and titanium retainers (on an RB25det-onation). Immediately picked up a sharper more RB26-like sound once they were fitted.
  • Confused 1
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7958617
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
