Hey guys,
So I know the headlight issue has been beaten to death at this point on GTR's but don't think I've seen this happen and I'm at a loss at this point.
The parking lights, interior lights, and tail lights ( when not on the brake) have all gone out. However, my headlights, high beams and turn signals all work.
The park lights setting on the switch does nothing, as well as the fog light button ( its wired to act as another park light button )
I've checked all fuses under the driver footwell, all are intact, tested with voltmeter and good to go. Also tested the relay under the hood as well.
Being the noob I am when it comes to electrical stuff and reading so much about the faulty switch and possible burnt out wiring, I went ahead and replaced both the interior light switch and harness to rule out. No Dice Same issue.
Ive traced out some wires off the interior harness. it appears there are 3 wires / separate circuit for park lights?
Im going to guess the Green with Red wire is battery feed? It also looks like its split into the fog light button which is making me believe is the issue.
Has anyone had this happen before?
https://www.sau.com.au/forums/topic/482783-r32-gtr-park-lights-issue/
You really need to start with some basic checks with a multimeter, that will tell you if power is getting to the switch and from the switch....there are too many places for this to fail after 30 years without knowing that
So just to clarify.
Ive checked all fuses in the engine bay as well as under dash with multi meter. all good. tested terminals fuses are in as well to check for power. all good.
I do NOT have a fusible link as my battery has been previously relocated to my trunk and on a breaker ( currently good to go)
I have traced the wires on the interior switch. The park circuit appears to be 3 wires / plugs on that switch,
a red wire with grey specs, a black wire with grey specs and a Green wire with red stripe.
I'm assuming that the green wire with the red stripe is supplying battery power as im currently getting nothing from said wire and it appears to be split/spliced into the cars fog light switch ( also acted as park lights switch )
To answer the above
Lowbeams, highbeams, dome lights and brake lights work. I have a dvd player and yes it works/ plays.
My park lights, taillights , and dash lights do not ( triple gauges out and haltech ic7 will not flip to night mode )
  • 4 weeks later...
9/28 update.
so I had a lil help and re traced and tested everything possible.
all fuses intact, power to fuse box on all slots.
Determined that the wiring in the dash for the headlight switch seems to be the culprit.
The green wire with red appears not to be getting any voltage what so ever.
also was able to backfeed on separate wire to test, all lights worked when doing so.
does anyone have a clear wiring diagram? my example sucks and cant seem to find any better....
need to find where this wire goes.
  • 3 years later...
Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY.
He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
  • Like 1
Yup. Mine was behind the dash. I guess after my IC7 install, the OEM cluster connectors were push into the dash, and the terminals (which are on the exterior of the connector so it contacts the traces in the cluster), contacted the chassis which caused my tail lamp fuse to blow. It also messed with my wideband. Taped them up and that fixed it.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
