Hi Guys
I'm look at getting a accsump for surge protection for my track car what size have people used? I was thinking a 2 quarts because of were I want to mount it but on the other hand the 3 quarts would be better for more capacity. Any advice would be greatly appreciated.
Cheers
https://www.sau.com.au/forums/topic/482792-accusump/
I may be wrong but i did some maths recently; at high rpm an upgraded oil pump is moving around a quart a second. So you can size the accusump for the length of protection you need.
A long corner on track might make for a few seconds of oil surge to make up for.
https://www.sau.com.au/forums/topic/482792-accusump/#findComment-7955452
I have a 3QT. It depends on how MUCH oil pressure you are losing, and how much oil the accusump has in it.
By this I don't mean only if its a 1/2/3QT. If you want the Accusump to deliver oil pressure quickly it means setting it up so more of the canister's internal area is taken up by air, not oil. They refer to this as the "pre charge PSI" but in reality it's taking up more space.
All the people refer to it as extra sump CAPACITY and how it operates is pretty bang on in regards to that aspect.
However.... You can never have too much protection from oil starvation.
If you have ECU failsafes on oil pressure this helps even more, you can tie the accsump in with sensors to know when they kick in, etc, so you will never 'run out'.
  • Like 1
https://www.sau.com.au/forums/topic/482792-accusump/#findComment-7955455
Cheers Kinkstaah
I've already got a winged sump head drain kit but still wana add the Accusump, do you know if you can mount it vertically? Also were abouts have you mounted yours quite afew I've seen mount around the area of the rad and intercooler but I'm not a fan of mounting it there incase it gets damaged while racing. I was thinking about mounting mine behind the drivers seat area.
Edited by couchboy
Need to add more info
https://www.sau.com.au/forums/topic/482792-accusump/#findComment-7955477
Given you said racing...  inside the cabin against the transmission tunnel where the passenger used to be seems common, So you can manually open/close them as you start/stop the motor which is the most reliable method. You can get a solenoid to do this, but it adds complexity and while it makes a lot of sense that it 'shouldn't fail.... the other option is a manual handle.
Corvette guys like to mount them just inside one of the guards, vertically but they get _reports_ of leaking from there. Mine is mounted horizontally, but given it's a cylinder full of pressurized oil, I can't really see how that'd change much...
My car no longer has a RB In it... and uh, it's mounted to the back of the front reinforcement bar. Not really an option with a front mount intercooler, but I don't have that either, so the routing to my oil cooler and where the oil cooler made a _LOT_ of sense for me.
https://www.sau.com.au/forums/topic/482792-accusump/#findComment-7955509
The big advantage with a electronic valve instead of manual is a dash light can be used to indicate immediately the valve opens. For my setup I'd basically shut the engine down if I saw the light which in a racing situation may be a second or so. Which means that the Accusump is used to avoid a momentary no oil situation, nothing more.
Edited by 260DET
https://www.sau.com.au/forums/topic/482792-accusump/#findComment-7955942
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
