Hey guys i own a er34 25gt Auto N/a and had a friend tell me that the revs go down fast right after you let off the gas is weird and sure enough when i hopped on his lancer i saw how his rev meter after he lets go of the gas goes down much much slower. Firstly does anyone know why it goes down much faster and second is it a good or bad thing?
Thanks guys
I've got to be honest, I don't really understand what you are describing...if the car drives smoothly and does not stall when you let off the throttle I would not be concerned
Yeah thats a fair call, theres no issue i can see from first glance concerning this. What i was trying to describe was that when i let go of the gas (Car is still rolling), the revs go back to neutral revs very quickly compared to my friends lancer
Back in the grim old days of carburetors, and particularly in the emissions era of carbies before EFI came along to save the day, a lot of carbies had a fairly significant dashpot on the throttle linkage to slow down the closure of the throttle. I used to hate that, particularly on an old Navara that we used to have on the farm.
Nowadays, the same thing is making a comeback in EFI cars, particularly newer ones with e-throttles. The manufacturers are doing it as an emissions control thing. I can't remember exactly what it is that a rapid close causes, probably NOx. Given that the Lancer is probably massively newer than your dirty old datto, and your dirty old datto certainly has no such dashpotting function, it's likely to be that.
  • Like 2
When you snap the throttle closed the primary concern is hydrocarbon shoot-through on the catalyst, if you suddenly snap the throttle closed you will pull high vacuum which will cause port injected engines to flash a bunch of fuel on the intake walls into vapor and cause a rich spike that is hard to control for, even with x-tau transient control it's normal to have a bit of a rich spike. Even with GDI engines it still seems to be challenging to control fuel in transients so the easy fix is to just smooth out the decay with drive by wire.
As for why an automatic from 20 years ago will have revs fall to near idle the instant you let off the accelerator vs a modern automatic or a manual transmission, the reason is that almost every older automatic I've driven unlocks the torque converter when you let off the gas and they don't lock the torque converter until you're at something like 64 kph anyways, it was mostly done to improve efficiency of the overdrive gear. Modern automatic transmissions in an effort to improve fuel efficiency will lock the torque converter as soon as 9 mph these days and depending upon what the ECU/TCU thinks you're doing will either keep the torque converter locked to keep the engine in DFCO to help slow down the car or it might unlock to reduce the amount of KE loss in coasting. Manual transmissions never had a torque converter so they don't have torque converter slip.
  • Like 2
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
