I am in process of refitting the aircon in my 32 With rb25 in it, swap was done by previous owner.
So heating and cooling lines have completely been deleted including compressor, I am aware that I need a rb25 compressor but what about the lines for both heating and cooling and wiring ?
Really appreciate any help, before I go to a ac place.
thanks
On 9/9/2021 at 5:21 PM, r32-25t said:
You need an r32 compressor and lines and everything else
Well..... So long as the R32 compressor doesn't have a problem with belt alignment, then yeah, sure. I don't know if there is a belt problem with a 32 compressor on a vanilla 25. I do know that the R32 compressor won't work against the Neo's belts. Well, not without having to do something about pulley alignment and/or different pulleys, which could all be possible, with some work.
I put a Neo into my R32, used the Neo/34 compressor, got an airconditioning workshop to cut and shut the refrigerant lines (R34 ends at the compressor onto the original R32 lines, welded at the alloy pipes).
I also had to f**k around endlessly to sort out the different pressure switch and the different way that the R34 ECU talks to the AC controller. Was without air for a couple of years until we got that sorted out. Not that it matters because I seldom use the air con anyway.
Oh, you also have to convert to R134a with the R34 compressor to, which means different receiver-dryer and ports and some other stuff.
Its a rb25det s2, so thinking of getting the compressor for which came on it originally, lining up things shouldn’t be a problem in that case.
Which I am more curious about are the lines.
will I need lines out of 32 or 33, I know it be different fitting here and there, but someone who has already gone through all this would be bonus.
@GTSBoy
please correct if wrong, all the things mentioned below are I figured will be needed as they are currently non existent.
r32 line from drier to condenser
1 ) Line from condenser to compressor? ( I believe fitting on condenser should be r32 ones and compressor side might be different)
2) Line from compressor to dash cooling unit ( same as above I think mix and match?)
3) Line from condenser to dash cooling unit
I am not 100% sure how exactly lines are on 32s, I am referring to the attached diagram.
Just want to suss out as much possible on my end, Eventually will be taking her to a ac shop to get it all going, but getting them to do all those fitting will land me to second job.
Appreciate your input.
On 10/09/2021 at 6:08 AM, r32-25t said:
I just did it the easy way and fitted the rb20 balancer on the rb25 but with the r33 rb25 the ac belts line up it’s just the power steering that doesn’t
Was thinking of doing that, how did ya line the power steering then ?
Used all the r32 accessories, alternator, power steering and alternator
  • Thanks 1
I can't help you with the details. As I said, I put a Neo25 into my car, and everything is different from vanilla25. And I did not use complete lines. I had the compressor ends of BOTH lines cut off the car's lines and I had the ends to suit the 34 compressor welded on.
  • Thanks 1
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
