Hey all,
Im finding it hard to determine this for sure. What I would like to know is if the elite 2500 uses the factory Nissan knock sensors at all?
Just asking as the wiring for the front knock sensor just got split and it's a pain to get in there and fix. So figured if it's not being used, why bother?
Thanks for the help!
Toby
https://www.sau.com.au/forums/topic/482814-knock-sensors-and-elite-2500/
It can, however if you have no knock strategies setup it does nothing.
For the Kebabtech to do anything you need to firstly enable them and have some form of igntion retard and/or fuel enrichment setup. By default, IIRC nothing is setup.
You could simply just press F4, search for knock sensor and untick the box and forget they're even connected.
  • Like 1
Thanks! I'll have a look when I have the car back together :) where in the software would I see if any knock strategies are setup? I sucks at using this Haltech software so far.... It doesn't seem overly intuitive unless you play around in it alot
So walked away from it and tried to get to the sensor connector again just then. Its amazing how something that seemed so  impossible before was so easy! Just didn't have my hand in the right place. Went back when fresh and got it off in a few seconds.
Ordered a new connector as the existing one has gotten super brittle, and it's not overly expensive. So easy fix in the end
I would definitely run the knock sensors especially if you鈥檙e pushing the performance envelope that most of us are.  If you鈥檙e running decent boost and advanced timing I think it鈥檚 asking for trouble to not have some engine protection built in around a knock threshold.
So I had a look in the ECU, there was no knock protection in place.
I also watched a lot of youtube to get a base understanding of how the Haltech worked. Started to get concerned with how my car was setup and there was minimal engine protection.
Then I also realised some basic things were not setup correct, such as the flex fuel sensor not being enabled when i supposedly got a flex tune done....
Also the IAT sensor was put wired into the SPI input and not the AVI, they then did an odd calibration based on this which made it look sort of correct on the dash, but was actually way off..
VCT was not being used....
Self Learning Fuel Trims were setup to only activate if the coolant temp was above 90c.....
God knows what else was wrong as i obviously have a very limited knowledge of the ECU.... literally based on a few HP Academy videos...
I mean if I could find these issues after what could be considered 2 hours of youtube...  how on earth can a "professional" who works at a well known shop here get it so wrong?
To say I'm p!ssed is an understatement.... Anyway its at a more reputable place now getting rectified... Turns out this new place has seen a lot of issues from the old place... so its fairly common from them, unfortunately....
Edited by Tobz
The reality is that good powertrain calibration engineers can land well-paying jobs at the OEMs and not deal with customers or customer service, so the tuners that most people can access on the open market are usually not the greatest. The consumers of tuning usually have no idea how to check stuff like this either so unless the tune is bad enough to break engines (not uncommon) there's no real verification.
I've basically accepted at this point I need to just DIY my tune. I don't like the idea of this but that's just how it goes. Maybe if I ever get my base map to a good state I'll post it up somewhere as open source.
Whoops sorry, totally missed this thread.
If it's not setup you won't see it enabled - easiest way is to hit F4 then go into Functions, then search for it. It would be under Knock Control (knock detection needs to be enabled first). Once enabled you will see it appear up in the functions list.
Using a knock calculator, such as this one for a stock motor the ~ frequency is 6700kHz for a slighter bigger bore 6600kHz (of course this is an implied frequency based on the diameter of the piston (doesn't factor in recessed areas, etc.)
https://phormula.com/knock-frequency-calculator/
Also, there's nothing wrong with using an SPI for temperature, it works perfectly fine provided you have the correct sensor data loaded up. I have mine like this (just because I ran out of inputs lol)
Yes, plenty of workshops don't bother with the small nitty gritty - they just focus on the dyno graph and the peak power.
Also, there's a high chance that "professional" just used a working map from a GT-R to use on your car, at the same time forgetting to enable VCT, etc.
No one ever starts from "scratch" as they say. When I tune cars for mates, I always tell them upfront I will be using XYZ map I made before for ABC car.
Also I can nearly guarantee you 9 our of 10 workshops never bother to fully dial in the fuel density table. I got this data from interpolating BP 98 data and ethanol density from an EVO forum. Sure it might not be accurate but it's better than having the same fuel density across the board for ethanol percentage and temperature.
Feel free to copy, however please note if your car as been tuned around a static fuel density, adding this in will affect your tune!
I think if it was thing that was a bit... o that seems odd, i would be ok, but it was so many things.... just lost faith...
Thanks for this :) nothing was in place.. which i totally understand as from what i read they can be very finicky to setup
What was interesting is the car was setup to run the same timing for e85 and 98
If you're runinng E85 however, you really need to cock it up big time to register any form of knock. Put it this way, if you ever manage to generate any kind of knock on E85 then you have bigger problems!
On E85 you could keep pumping in timing, literally fall face down with power and still it won't knock! Going past MBT and the motor will be fine (I'm a bit guilty of this, I will add timing till I see a loss in power and i know it's good to stop LOLOLOL)
it might be hidden in a 3rd dimension somewhere, I generally just use the compensation table to do E85
How I like to do it, however MoTec guys like to use a 3rd dimension in their main ignition table
How MoTec tuners like to do it (note the slider at the bottom), also what you see there is my 98 map, although the slider is dragged to E80 - it's because I use the compensation tables instead
  • Like 1
That's interesting...  although meant nothing as the flex fuel sensor in my car was disabled... I did ask them a few times why my dash would always say 85% ethanol even when i had 98 in it.... and enquired why my AFR was 8:1 when on 98... was told not to worry and its all fine... seemed very odd to me though
LOL... jesus...
Yeah not having the flex sensor is just like having a straight E85 tune and pouring in 98. Great way to wash the bores and foul your plugs.
Too bad you're not from the hood - would happily show you things in person on the dyno.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 馃構 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
