G’day all, just bought a 370GT and looking at this stainless Invidia Gemini system. When I bought the car it had a straight through system (had the resonators and muffler removed) that sounded filthy. Got them put back on and now it is stock (even more filthy).
First question; How do you guys rate this system?
Second question; Any recommendations as to where I could pick up a system other than EBay (preferably in SA)
I’m also looking at short ram intakes, any issues with bolting a set straight on? Or will it need to be tuned after putting them on? Any recommendations on a set that are good value and do the trick?
thanks all,
https://www.sau.com.au/forums/topic/482818-370gt-exhaust-invidia-gemini/
I think invidia have an Aus based warehouse so they should able to help you out. Alternatively try jdmaccessories etc or another jam parts store. If you don’t mind a slightly longer wait, buy from the states.
Stock intakes with high flow panel filters & silicone upper tubes perform exceptionally well. Better than short rams & on par with long tubes, for half the price. Short ram intakes suck the hot air from the engine bay, reducing performance.
Congrats on your new purchase 👍
No tune needed after putting on intakes or exhaust. But if you do get a tune you will get better performance.
Sound of the exhaust.... beauty is in the ear of the beholder.
  • Like 1
If it's more about producing a tasteful note, I recommend just replacing the muffler like I did, with a Megan Racing one. It's half the cost and has a very tasteful note that even old geezers would appreciate. I had to get my exhaust guy to cut off and replace those ricey burnt titanium tips with regular oval chrome tips.
But, as Paul just said, beauty is in the ear of the beholder.
    • Hi, We've all posted some thread, or know of some other person's thread, that contains information that we want to send people who are asking question to. But if we don't have a link readily available, have to go do a search for the thread before being able to do so. So, it occurred to me that we could possibly utilise the auto-text-replace function that fixes some of my swear words to perhaps auto replace some special keywords with text that also has a link to the thread. A specific example. The thread that I did with the improved R32 GTR wiring diagram scans. If the phrase "R32 GTR wiring diagram" could be auto replaced with "R32 GTR wiring diagram" then all I (or @Duncan, or any of the others that refer to the thread) need to do is remember that that's the keyword (or phrase in this case). OK, it would be better if this keyphrase wasn't that long, but it does need to be specific enough that it doesn't get triggered automatically. And obviously there are threads on turbo topics, or suspension topics that we could treat similarly. Alternatively (and/or additionally), I've been thinking about trying to build a library of the real expert content that is trapped in the bowels of the 25odd years of this site. Things like some of SydneyKid's content. There are threads that he started that should be more easily found, and he has individual posts, or series of posts, in other people's threads, containing very good information. Some of us know that it is there, but....just have no memory of exactly where/when/how we saw it. If we had some sort of library thread, we could put posts in there containing links to things we've found, suggestions for how to categorise it, then a mod or other appointed thread maintainer can copy the link and any key text up into the first post in the library thread. There are probably many other ways to get it done. Some sort of wiki is probably the best way.   Thoughts?
    • But, probably that happened to the last person too, which is why the RTV was there.....if you aren't putting a new gasket in you will need to seal the old gasket back to the metal surface with something, the gaskets will generally only work properly for a single use as they set/harden in that shape
    • What is with the horrible blue and white bit in the centre of the wheels, didn't that come off with some scrubbing?
    • Not sure how broadly you define Northside  but Castle Hill Exhaust are still around and could sort it.
    • I haven't done this as I still use the factory cluster, but I do know the circuits for the flash vs on for hi beam are separate which is likely the issue. The ON runs full power through the switch and the flash uses the relay in the engine bay. I'd hit the wiring diagram per GTSBoy's suggestion
