Hi all, after some code guessing last week I purchased some new Kazama Auto ignition coils (red ones). After installation, and driving about 30kms, the car developed a misfire.
Last night I identified it as coil number one. I unplugged each coil to find the faulty bugger only to realise I could do the check with Nisdatascan.
First time round I didnt apply any dielectric grease. So, last night I went ahead and applied the grease to see if it would rectify the issue; this is when I found the boot on one of the coil packs appeared to be disfigured at the tip, probably from heat-damage (see pic).
I then went ahead and dropped in one of the old coils which appeared to rectify the issue, at least for the five mins I ran the car for after.
Now, I'm looking to return the coil pack and preferably get a single replacement for the dud, but it would help if I could explain why this may have happened? I've bought cheap coils before that have been dead on arrival but wouldn't expect this from a name brand - despite they're probably less-than-OEM quality.
The engine and ECU is stock - there is no third-party wiring apart from for the AT-MT swap. I checked the harness in the wheel arch for damage - as the car is low and running larger wheels - it's visually intact. The ignition coil harness appeared to have been replaced by the previous owner. I replaced the plugs this time round.
Just FYI: the coils didn't need replacing in the first place, after getting intermittent error codes which seemed to clear once they disappeared from the dash, I guessed it may have been the ignition coils. Actually, it was code 17, for the TCS motor to which I've got another on the way now.
You broke the first rule of buying RB coils.
The first rule: Thou shalt not buy other than OEM or Splitfire.
The first rule has now been superceded by the new rule, which is;
The new rule: Why would you put original form factor coils into an RB when you can buy kits containing modern pencil coils (Yaris, Audi, VQ, R35, etc) for reasonably sensible money and enjoy umpteen times better spark output? Not to mention that should a pencil coil die, a new one is often only ~$50.
  • Like 1
  • Haha 3
Hahaha, noted. I was unfortunately way too uninformed to do this. Not to mention the rule of 'if it aint broke don't fix it'.
But in light of my mistake, and you having heaps of experience with these cars, would you be able to share any info that may help my case?
Yes, rainbow coils are a lottery and should be avoided. You need to buy 2 sets so that you can swap them out. Usually one or 2 of the first set will be dead out of the box. Then you'll lose others at random intervals.
Ignore all the people who usually chime in at this point in these threads with "But I put in yellow coils 5 years ago and they've been fine", or "My red ones have been great". They got lucky. They are at the far right hand end of those coils' bell curve. Your typical owner of such coils is closer to the middle of the bell curve, and that is well to the left of the bell curve of OEMs & Splitfires. There have been so very many threads about dead OOB and short life expectancy rainbow coils for it not to be true.
  • Like 1
Thanks GTSboy appreciate the detail a lot. I understand it's a lottery with these, although, I was under the impression with them being endorsed by Kazama Auto they'd be better. A mechanic friend of mine enlightened me by saying "you know those are Chinese too, right?"
It seems like I would be best off returning the set and whacking the generic Hanshin back in.
Yeah remember the fake OEM ones on eBay a few years ago?
Yellow Jack equipped car owner here, they were cheap quick fix for my dying OEM coils, car runs okay but I can hear the ignition start to break down on hot days/under heavy load hahaha. I'll look at changing them once the standard ceramic turbos come off.
I looked up the price of OEM coils and the prices are nuts if you can't find some special pricing. You can get R35 Hitachi coils from Rockauto in the US for like 60 USD each. As far as I can tell they don't really have a counterfeit part problem either.
Edited by joshuaho96
  • Like 1
Probably wouldn't matter if they did anyway. Pencil coil tech is so much newer/better that a bodgy counterfeit is probably good enough. At least they'd be copying something that you only have to get 80% right to be able to run an RB, whereas if you're trying to fake an old RB coil, you have to get it all the way to OEM/Splitfire quality to do the job.
  • Like 1
Appreciate this. I should've researched more tbh, as this seems like a better route. I was a sucker for them being sold by Kazama Auto, a fairly reputable company over in Japan. The company are replacing them under warranty; they have one set left, so presumably, if the next batch fail I can get a refund.
The Kazama Auto coils have pretty good reviews on the Japanese sites, although most seem to describe what is essentially placebo. There's quite a few 1JZs running them as far as i could see.
They mentioned in my returns email it's not advisable to run 5x Kazama "high intensity coils" plus 1x other brand, although in my experience, mix and match coils hasn't been a problem.
On 9/15/2021 at 4:40 PM, Dose Pipe Sutututu said:
Or get the replacement coil / coil set and sell it.
Buy R35 coil kit - call it a day!
Good call, and normally that would be an easy option, say, if I were still in the UK. Selling to the Japanese in Japan (as a foreigner) carries it's own problems. I'll have to give this a bit more thought when I receive the replacements.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
